Can Audition/CEP handle recording to multiple tracks at once?
Really, that's it. Is it capable of recording from all of the inputs to different tracks with my Delta-66?
AND,anyone know which programs can and cannot support this? Thanks in advance. Kore |
the question is can your PC handle it. CEP/AA can handle recording a ton of tracks at once but it is limited by the speed and power of your PC. What are your PC's specs? CEP/AA takes a lot of memory so you will want at least 512. A second harddrive woulndt be a bad idea either.
Playback could be an issue as well...on an older PC of mine (256 RAM, 650 mhz), I had trouble playing back more than 25 tracks or so at once....thats if they were recorded at 44.1....if they were at 96Hz I could handle about half that if i was lucky. |
Thanks for the replies. Just a few other follow-ups.
1) What is the correct term for "recording to different tracks simultaneously?" 2) HOW do you set up Audition to record from a specific channel? All I know how to do is click on the red "R" block, or to not click on it--how do I set 3 to record and select which channel each one records? Thanks so much. |
1. multitracking.
2. when you hit your "record in" button" that i described before, all possible choices for inputs should be listed. you simply choose your input along with left, right, or stereo. If your inputs are configured properly, CEP/AA will detect them and they will be listed in the menu. |
Also note, that you must use the supplied WDM drivers as CEP/AA doesn't operate with ASIO drivers.
http://www.changehiphop.com/images/pics/Signature.jpg Preview of the new Album here!!! Mixing and Mastering services for your project, contact change@changehiphop.com |
| Recording Roland V-drum tracks | VertuGoGo | Cakewalk / Sonar Forum | 12 | 09-16-2002 05:04 |
| Multiple Midi tracks | L'espion Noir | Cubase User Forum | 1 | 08-13-2002 18:31 |
| How Do I Bounce Tracks on an Analog Machine? | alloutdrummer | Recording Techniques | 12 | 07-07-2002 05:38 |
| Problems getting Aark Playback of laid tracks thru Headphones while recording audio | bloozguy | Cakewalk / Sonar Forum | 10 | 10-26-2001 15:21 |
