Old 01-13-2005
Kore Kore is offline
Junior Member
Kore is on a distinguished road
What programs support simultaneous multi-tracking?
Hi, I'm a newb. I currently use Audition, and am thinking of getting an Delta 66, but am not sure if Audition supports recording to different tracks from different channels simultaneously. I'm also interested in what other programs would support this.
I currently have a 6 channel mixer, which is fine for doing basic, lo-fi drums recording, but I have to mix it to 2 stereo channels before I input into my computer. I would much prefer to do separate channel mixing post-recording, and to do this, of course, I need to record each input to a different track. What sound card/sound drivers/programs support this and are compatible with each other?
Thanks for your help.
Kore
Old 01-13-2005
Tifstorey's Avatar
Tifstorey Tifstorey is offline
Guinea Pig
Tifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond repute
Hi Kore,
Well its all a part of trying them all out really. Considering music software can run into the hundreds of pounds, i would highly suggest you seek out some way of testing the programmes hands on. Personally, i use Cubase SX which has everything i want, including be able to handle simultaneous recording. Cubase also do a "watered" down version of SX which retails at around £80 ( Cubase SE) which i think would be a wise choice for you. But like i said, try and give them all a try and see which you prefer. (Might also want to have a look at Logic, Ableton Live, Cakewalk and Cubase^)
Regarding Soundcards, The Delta 66 is a good overall sound card, and sounds perfect for what your wanting to do.
Hope this helps you a little bit on your way,
Good luck!!
Peace
Old 01-13-2005
gordone's Avatar
gordone gordone is offline
1K Silver Member
gordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond repute
Don't forget N-Track. About $60. I've been using it for years with my Delta 44, can record multiple tracks no problem (provided your PC can handle it)
Old 01-13-2005
Junior Member
Okay, then. . . what programs DO NOT allow simultaneous multitrack recording?
AND, what is the REAL term for the one I made up: "simultaneous multitrack recording"--this would make it easier for me to do searches.
Old 01-14-2005
Tifstorey's Avatar
Guinea Pig
Personally, most programmes i know of can record multiple tracks at a time, if they didnt, they wouldnt be the best piece of software. I cant actually name a piece of software that doesnt do it...
Regarding the term for "simultaneous multi track recording"... I would suggest its "multi track recording", although i call it that, other people may not do. So this post hasnt been the most educational for you, i apologise.
Peace
Old 01-14-2005
MadAudio's Avatar
MadAudio MadAudio is offline
Damned if I do
MadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond repute
Acid can only record one track at a time, though that program is meant more for loop-based material anyway.
Exactly what mixer are you using? I'm guessing it doesn't have inserts on the channels. You're probably going to need to upgrade your mixer to get independent outs to the soundcard.
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music.
"Do yourself a favour just shut up, read up then put up." --muttley600
Digi 002, Multi Tracking vbass62 Digital Recording & Computers 9 03-27-2004 18:07
Fostex FD-8: does it support simultaneous recording of 8 analog inputs? rboyce_boston Fostex Forum 6 10-26-2003 19:11
Which programs support 88.2 kHz sampling rate? Bigus Dickus Digital Recording & Computers 0 12-11-2002 12:09
multi tracking sound cards herobot Digital Recording & Computers 4 11-23-2001 20:51
simultaneous tracking Pete Kopplin Newbies 2 07-18-2000 16:56
