Old 01-12-2005
Steal Sessions Steal Sessions is offline
Junior Member
Steal Sessions is on a distinguished road
Tips on recording semi-acousic guitar
Tomorrow the guitar player of our 'project' is going to visit me at my place to record a few parts of a bunch of songs (intro's) using a semi-acoustic guitar. He wanted to know if he should bring his (old) RP1 effect machine for a decent line-signal to be recorded. Well, I was basically thinking I'd be recording the acoustic signal with (condensator?) mics and blending that with the signal from the element/pick-up inside the guitar. I do not know specs about the guitar and/or used element/pick-up. What would you recomend for recording that type of guitar, using mics/or not, using the elements/or not, blending mic & pickup lateron in the mix or use only one source for recording. I need it to blend nicely with a very heavy rock tune that starts right after the intro.
My gear:
-Sonar 2.2, 2.2GHz, 512 MB mem, Delta1010LT, M-Audio DualMP3, Phonic (I know..) 4 ch. mic mixer and many many cables. Also a drum-mic set with 3 condensormics (el-cheapo, Collins).
I think I'll set him up in the room I have that sould be pretty 'dead' due to carpeting, wood in/on the walls ect. We'll plug his element into the RP1 and allow him to set up a decent sound he likes (via my crappy monitor speakers using the RP1 stuff at a minimum, volume & eq only) and blends nicely with the stuff it has to fit to. Also I'll setup a small condensor mic (one of my Collins-8 piece mic-drumset) to pick up the acoustic stuff inside the room. He can play with the clicktrack and his guitar sound on a headphone (but quite soft, since the mic might pick it up, and he's supposed to play that intro alone). These are really small parts he's to play, but I want a decent sound and a decent performance.. I'm pretty sick with editing the other stuff we've recorded, so this intro-stuff has to be right as it is. Having the right ideas about the setup might help doing just that .
Thanks guys/lads.
Old 01-12-2005
Rokket's Avatar
Rokket Rokket is offline
SGT Floyd Pepper
Rokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond repute
My gear:
Thanks guys/lads.
Go with your first insticts and record it mic'd up first, maybe with 2 mics and record it DI'd. Personally, I would avoid using the RP1. They can get a bit noisy.
Experiment with mic placement and do a few dry runs. If you can place two mics, try one at the 12th fret pointed at a slight angle to the sound hole, and one over his fretting hand shoulder at just slightly below ear level.
Then DI it and see what it sounds like.
If I had a nickel every time a woman told me to get lost, I'd be able to buy Manhattan.
http://www.youtube.com/user/MrEstorey
Old 01-12-2005
Junior Member
Check. That RP1 idea was just for the impedance matching, allthough I guess plugging the element-pick-up directly in my DMP3 jack-direct input would be the 'cleanest' way to go. 100kOhms input impedance should be fine with a semi-acoustic pick-up I guess. The 2-microphone idea I've read about before.. Just like mic-ing an acoustic guitar I guess. Not a bad idea for the stereo image and such I guess. I'll try it and post what I got lateron. Thanks.
Old 01-12-2005
Junior Member
Ah, another question on this one, if I may? There are also a few solo's I've to record while using electric guitar. The question is that since we cannot record a full stack (allthough the rest of the recording is done with a full stack, but this would be only a solo, easier to blend I guess) which methode to use then. I was thinking the RP1 again, but maybe would it be wise to record it directly into the DAW and use an amp modeller & speaker sim to add eq, distortion and tube feel. Which one of these would get us the best results? Any other idea's?
Old 01-12-2005
mattamatta's Avatar
mattamatta mattamatta is offline
Force of Nature
Location: I told my friend that his anus was so big, that he had to get a restraining order for the local caving club.
mattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond repute
Use a smaller amp =D
No reason you have to use a full stack, especially recording, and especially a solo, as it will probably need to fit into less sonic space to work.
Or an amp modeler would work if you have no other suitable amps to mic.
Old 01-14-2005
Junior Member
You are not going to believe this! Yesterday we recorded the required intro-thingies on semi- acoustic guitar (sound-wise it really went well, using 2 condensor mics, playing around with positions, making sure the 3:1 rule was applied.. souds great). The funny part is that I could hear something rattle a bit somewhere in/from that guitar so we did an closer inspection. Just for the background: our guitar player does not own this guitar, he only lend it from a friend of his.. He practised a bit on it during the last week (but not enough, considering the results ) but he didn't notice that ratling sound. After inspectation and playing around a bit we recovered something from the inside of the guitar, it hung fixed between the wiring inside the guitar, but still managed to ratle quite a bit:
Amazing huh? This guitar is at least 2 years owned by this friend.. He never noticed...
Funny buisiness this recording stuff is indeed..
Distorted Guitar Recording, Mesa Boogie Amp jdier Microphones 24 01-12-2007 06:35
Tips on recording guitar with my setup. bloodloss Recording Techniques 2 07-08-2003 00:56
Recording my guitar with line in The Corsairs Cakewalk / Sonar Forum 1 12-28-2002 18:56
Recording and editing a guitar line gordholio Newbies 12 12-12-2002 15:25
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
