Go Back   Home Recording > User Forums by Brand > Cool Edit Pro / Adobe Audition Forum
Reply    Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 01-11-2005
chizzle chizzle is offline
Newbie
chizzle is on a distinguished road
missing a channel
when i'm recording my vocals for some reason I'm getting one sided audio instead of two channels. why isn't my mic feed stereo? any ideas.
What I have been doing is converting the file to mono, this is how I work around it. . . cause I can't figure it out!
Old 01-11-2005
MadAudio's Avatar
MadAudio MadAudio is offline
Damned if I do
MadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond repute
What soundcard, what software, what mic, how's it connected? I can't see your computer from here!
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music.
"Do yourself a favour just shut up, read up then put up." --muttley600
Old 01-11-2005
thajeremy's Avatar
thajeremy thajeremy is offline
registered abuser
thajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond repute
yea....what he said...
Old 01-12-2005
Strryder Strryder is offline
Force of Nature
Strryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond repute
A single microphone is a mono device, as are most electric basses and guitars.
While it is possible to use either a "Y" cable, or sometimes a software setting to record a single mono source onto both sides of a stereo track, the most common method of recording a mono source is on a mono track, instead of two "sides", the track will only have a single waveform in the middle, on playback the mono sound can then be shfted to the left or right by using the pan control.
Old 01-12-2005
Newbie
okay....emachine (can't remember - 2825 I think, I'll check when I'm home)
512/120.......cool edit.........with the lexicon omega desktop package....marshall 990 mic
Old 01-13-2005
thajeremy's Avatar
registered abuser
go to your multitrack view of cool edit. to the left of each track, you should see things like the record button (red and has an R in it), solo button (yellow with an S) and a mute button (green with an M). Below those buttons, there should be an IN and OUT button. click the in button and your input devices options should come up. Yours is probably set to record in stereo. change that to either right or left depending on what side you are getting your signal recorded to. This will cause it to record in mono and you will just get one wav down the middle of the track and you can then use panning to get your stereo effect with the other tracks.
Old 01-13-2005
chrisharris's Avatar
chrisharris chrisharris is offline
Smartest Guy In The Room
chrisharris has a reputation beyond reputechrisharris has a reputation beyond reputechrisharris has a reputation beyond reputechrisharris has a reputation beyond reputechrisharris has a reputation beyond reputechrisharris has a reputation beyond reputechrisharris has a reputation beyond reputechrisharris has a reputation beyond reputechrisharris has a reputation beyond reputechrisharris has a reputation beyond reputechrisharris has a reputation beyond repute
yeah, what he said. And just to punctuate the point a bit, all you're doing if you're recording that mic in stereo is wasting hard drive space. Even if you record in "stereo," all it'll do is take the exact same signal and put it on the left and the right...which is mono.
Originally Posted by Greg_L View Post
I'm not gonna use 3 mics per drum and sidechain some vintage tube compressor that Keith Richards once ejaculated on. Nope, I'm gonna plug into my Firepod, fire up Reaper, and rock the fuck out.
Old 01-13-2005
Change of POETS's Avatar
Change of POETS Change of POETS is offline
Boom Bap
Change of POETS has a reputation beyond reputeChange of POETS has a reputation beyond reputeChange of POETS has a reputation beyond reputeChange of POETS has a reputation beyond reputeChange of POETS has a reputation beyond reputeChange of POETS has a reputation beyond reputeChange of POETS has a reputation beyond reputeChange of POETS has a reputation beyond reputeChange of POETS has a reputation beyond reputeChange of POETS has a reputation beyond reputeChange of POETS has a reputation beyond repute
Exactly. Unless you're using a dual mic setup on dual channels, you're not recording in stereo...
So many people confuse that... I know when I was a newbie, I did.
http://www.changehiphop.com/images/pics/Signature.jpg
Preview of the new Album here!!!
Mixing and Mastering services for your project, contact change@changehiphop.com
Old 01-18-2005
Newbie
Thanks to all of you
just now getting back to the site haven't gotten back home yet to tweak and adjust....but I also noticed I've really got to do some adjusting . . . cause all sources last i checked yielded the exact same results....CD player, drum machine, sampler - clearly I'm doing something really stupid that I'm overlooking...will keep all posted.
Old 01-19-2005
rapedbyape rapedbyape is offline
Junior Member
rapedbyape is an unknown quantity at this point
I used to record everything in stereo when I first started out going from a mixer into the line-in of a a soundcard. It seems kind of stupid now but I didn't realise that at the time.
Old 01-19-2005
Boom Bap
More confusion.
  #12
Old 01-19-2005
Junior Member
Ah, you know what I mean. I used to record everything from a mono source as a stereo signal.
  #13
Old 01-19-2005
dobro dobro is offline
Moderator
dobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond repute
Okay, illuminate me.
I can see how recording a mono source in stereo is a giant waste of time.
But when would you record in stereo, then? If you're putting two mics on an instrument (I do that with guitar), wouldn't you route each mic to its own mono track? That's what I do. So, what's the point of recording in stereo?
  #14
Old 01-20-2005
Boom Bap
I still do that, and I honestly don't see why I wouldn't...
It gives a more full sound than a mono track panned center, IMO. Or I just like seeing the pretty waveforms on both sides of the form... I'm not sure...lol..
  #15
Old 01-20-2005
Boom Bap
Well, it's good for instrumentation like you stated, as you don't have a need to layer guitars etc, with multiple takes. It's nice in that aspect.
Vocally, there isn't much need for it at all, unless running the seperate signals through different processors or effects racks for a different layered sound. I know Celine Dion has done this quite a bit, as well as Cher, and Madonna. It's easier on the Engineer and the artist, reducing studio time needed and amount of takes.
As for home studio applications, I don't see a vocal need for it, but I only record Hip-Hop and some adult contemporary groups...
Mixer to computer question? Only get left channel trippinants13 Newbies 5 12-30-2004 14:37
Getting the most out of my behringer 8 channel mixer… Gunther Newbies 8 02-12-2003 20:51
Difference between SEND and INSERT in cubase Gabriel Sousa Digital Recording & Computers 4 01-27-2003 12:48
Resilient Channel LDQ Studio Building & Display 1 01-23-2003 13:26
ONE channel MIDI synths.. electronicdreaming MIDI Mania 4 02-24-2002 15:12
