Old 01-09-2005
washingtonbc washingtonbc is offline
Newbie
washingtonbc is on a distinguished road
How to record backwards vocals?
Anyone have an idea how to do this? I have a spooky tune that I want to put backwards speech in. I am recording on a Yamaha aw16g. I also have a two track reel to reel.
BC
Old 01-09-2005
jake-owa's Avatar
jake-owa jake-owa is offline
Banned
jake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud of
There should be some tool in the Yamaha to reverse files. Somewhere in the menu there should be an invert phase and reverse command. Did you check the manual? If not you could try to record the vocals to a track of tape while recording a mix reference to another track. Then record the tape back to computer using the mix reference to align the vocals while cutting the file up. It would be time consuming but probably doable. The other option is you can cue up the tape and fly the vocals in on the fly. Rediculously hard but also possible.
Yet another way would be to burn a CD of the mix, transfer to a computer and use and multitrack editor to reverse the mix file and sing to the backwards mix. Then you reverse the audio file, burn it off and line it up in the DAW. OR....you could practice singing it backwards and record it straight.
No easy answer here, unless your DAW let's you do it.
This all depends on what type of backwards you want. Do you want the vocal to be each word backwards but the vocal being linear or do you want the whole thing sung back to front backwards as well?
ANSWERS, I NEED ANSWERS!
And some more coffee.
Old 01-09-2005
EVT EVT is offline
Dedicated Member
EVT has a reputation beyond reputeEVT has a reputation beyond reputeEVT has a reputation beyond reputeEVT has a reputation beyond reputeEVT has a reputation beyond reputeEVT has a reputation beyond reputeEVT has a reputation beyond reputeEVT has a reputation beyond reputeEVT has a reputation beyond reputeEVT has a reputation beyond reputeEVT has a reputation beyond repute
Hi washingtonbc,
I've actually done that in the past using a sampler. Roland sp808, and i have an older sampler that also does it but only has a little bit of sampling time it's an older sampler... akai s20. I think most samplers probably have that function. Or even software samplers I'm sure have a lot of options for manipulating tracks.
If you're interested in checking it out, the song called evibe (vibe) is the song that I reversed my vocals on.
http://www.getunderground.com/underg...fm?Album_ID=45
Well good luck!
evt
Old 01-09-2005
Rokket's Avatar
Rokket Rokket is offline
Sgt Floyd Pepper
Rokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond repute
Try to record it on the reel to reel and flipping the tape around. I used to do that with my cassettes on my 4-track. It's a bit easier to do with a reel to reel. doing it on a cassette meant taking it apart.
The hardest part of being a bartender is figuring out who is drunk, and who is just plain stupid.
Old 01-09-2005
Light's Avatar
Light Light is offline
Born in the Light ofStars
Location: Creating saw dust at rapidly increasing levels
Light has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond repute
Record it on the real to real, and then flip the tape, and record it into the DAW. Edit and move in the DAW until you have the effect you are after.
Light
"Cowards can never be moral."
M.K. Gandhi
Old 01-09-2005
freak1c freak1c is offline
Junior Member
freak1c is on a distinguished road
just flip the reels.
Old 02-02-2005
dgatwood's Avatar
dgatwood dgatwood is offline
is out. Leave a message.
dgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond repute
Or for a fun effect, record on the reel-to-reel, then play it back by hand-winding it backwards. Start slow, and vary your speed. Or do it by hitting rewind for a nice reverse that gets faster and faster. Fade it out, loop it, add tons of reverb, and see what happens....
Note: you may have to hold down play to hear while rewinding on some open reels....
Old 02-02-2005
usernamebob usernamebob is offline
Senior Member
usernamebob is on a distinguished road
Get the singer to sing into the back of the mic
Old 02-02-2005
deepwater deepwater is offline
1K Silver Member
deepwater has a spectacular aura aboutdeepwater has a spectacular aura aboutdeepwater has a spectacular aura about
Take your mic cable a part and swape pins 1 and 3
The most popular HR member - just do a search
Old 02-02-2005
scrubs's Avatar
scrubs scrubs is offline
Not of sound mind
scrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond repute
"That was so terrible, I think you gave me cancer!"
My tunage
Old 02-02-2005
Todzilla's Avatar
Todzilla Todzilla is offline
Force of Nature
Todzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond repute
!daed Si Luap
!nam Daed ,no Em Nrut
Insect Massage Therapist
HUGE sound generation & capture facility
http://www.toddejones.com
  #12
Old 02-02-2005
reshp1's Avatar
reshp1 reshp1 is offline
1K Silver Member
reshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond repute
Record the vocal as a .wav file and use the stock Windows sound recorder. That has a reverse option under the effects menu.
  #13
Old 02-02-2005
punkin's Avatar
punkin punkin is offline
Univalve & Avatar Speaks
punkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond repute
That's a great suggestion reshp1...I was going to add that SONAR has the ability as well.
How large a file are we talking? If you can't get it worked out, I would be willing to do it for you.
She's not the boss of me
  #14
Old 02-02-2005
Newbie
Already done.
Thanks for your suggestions. I found a way to do it on my AW16G.
The AW16G is an amazing machine!
BC
  #15
Old 02-02-2005
TBPlayer TBPlayer is offline
Newbie
TBPlayer is on a distinguished road
Hey, how did you do it on the AW16G? I own one and I when I read your question I was thinking that there wasn't any way to do it.
-Phil
  #16
Old 02-03-2005
honedawg's Avatar
honedawg honedawg is offline
Junior Member
honedawg has a reputation beyond reputehonedawg has a reputation beyond reputehonedawg has a reputation beyond reputehonedawg has a reputation beyond reputehonedawg has a reputation beyond reputehonedawg has a reputation beyond reputehonedawg has a reputation beyond reputehonedawg has a reputation beyond reputehonedawg has a reputation beyond reputehonedawg has a reputation beyond reputehonedawg has a reputation beyond repute
Copy and Paste
If it's like my Zoom you can copy a track and when you paste it you have a choice of how you want to paste it. One of the choices is to reverse it.
People who record vocals with SM57 please help me! arkitech Microphones 19 08-17-2004 11:59
If I want to record vocals dragonworks Microphones 32 12-30-2003 16:59
Trying to record vocals vicevursa Cakewalk / Sonar Forum 19 01-14-2003 09:13
headphone record vocals problem platinumcool Recording Techniques 4 05-21-2002 09:53
What is the best way to record group vocals Link Recording Techniques 13 05-18-2000 00:02
