Old 01-07-2005
Alexbt's Avatar
Alexbt Alexbt is offline
Force of Nature
Alexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond repute
Reducing wind/pop on vocals
Hi all,
I got my Delta 1010LT today, and was doing some live vocal/piano takes.
I was having some levels difficulties, but that's for another topic...
Is there any good way to eliminate the wind/pop noise when singing?
I may have to get a windscreen or pop screen but it could be a little while before i go out and get one.
Any temporary ideas?
Thanks,
Alex
Old 01-07-2005
Rokket's Avatar
Rokket Rokket is offline
Sgt Floyd Pepper
Rokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond repute
A cheap fix for that until you get a pop filter is to wrap a sock around the head of the mic. It will help a little with the wind/popping. Wind screen can be gotten for about a dollar, and are meant more for live performance. For recording you will need a pop filter. Get one as soon as you can, because while a sock will help some, it will also cut out some of the higher frequencies and your vocals will sound muddy.
The hardest part of being a bartender is figuring out who is drunk, and who is just plain stupid.
Old 01-07-2005
bigwillz24's Avatar
bigwillz24 bigwillz24 is offline
One Turd at a Time...
bigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond repute
Get a wire hanger and a pair of panty hose. Make the wire hanger into a balloon with a string shape. Then strecth the panty hose over the "balloon" part. Tie the "string" part off to the mic stand and position the "balloon" part about 1 to 3 inches in front of the microphone.
Congradulations you just gave birth to a pop filter.
Old 01-08-2005
NYMorningstar NYMorningstar is offline
Recording Modus Operandi
NYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond repute
Back off the mic.
Old 01-08-2005
Alexbt's Avatar
Force of Nature
Thanks, I'll try the suggestions.
The homemade pop filter sounds like a good idea.
I'll try it out.
As for backing off the mic, for some reason, I am the only person who doesn't think that Delta's preamps are too loud. That or my mic is very soft. I would have to add more gain in the control panel to get it at the loudness I would require to back off the mic, but I can play around with it and see how it works.
Old 01-08-2005
notbradsohner notbradsohner is offline
Compression Addict
notbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond repute
stick a pencil directly in front of the mics capsule, right in the middle. This will diffuse the rush of air in two ways, thus reducing some "pop"
when the dust all settles and all of us have gone our life ways, the only thing anybody will care about in those recordings is the content. The songs and how they are performed. - SouthSIDE Glen
Old 01-08-2005
AGCurry AGCurry is offline
Force of Nature
AGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond repute
When someone sings, the air from his mouth flows in a somewhat downward direction. Place the mic in front of your nose, pointed down at your mouth. That should help. Otherwise, you need a pop filter.
Old 01-09-2005
Alexbt's Avatar
Force of Nature
As for the pencil, I'm not quite sure I understand.
I'll try the 'nose' placement though, and see how it works.
where do you sit your vocals? jugalo180 DJ & Hip Hop Production 5 03-31-2006 12:31
Removing Vocals from CDs Knopfler Fan Newbies 7 11-08-2005 11:51
Recording vocals tricks arsenaultk9 Microphones 26 12-30-2004 20:43
Digging a hole for vocals ambi Mixing / Mastering 8 01-24-2003 17:28
'Ghost Vocals' hybridsound Recording Techniques 4 12-30-2002 13:47
