Go Back   Home Recording > User Forums by Brand > Roland, Boss, VS Series Forum
Reply    Audiofanzine Roland boss Roland boss News Roland boss Medias Roland boss Tests Roland boss Articles Roland boss User Reviews Roland boss Classifieds Ads
Old 01-04-2005
Foo-bu Foo-bu is offline
Senior Member
Foo-bu is a jewel in the roughFoo-bu is a jewel in the roughFoo-bu is a jewel in the rough
need help mastering with my vs2400
hey everyone, i was wondering if any of you could help me out or find the weak link in my chain.
the problem i've run into deals with adding compression to master tracks.
basically what i normally do is record all the tracks and then mix them in MTP mode. when i'm done mixing them i use the mastering room record feature to save my mix to 2 tracks.
from here is where i get confused...
if i want to EQ or add compression to the master track, how would i do it? i cant seem to do it in MTP mode. i've tried using dynamic processing on track 24/virtual track 24 (the default for master tracks) but nothing works.
normally what i do when burning a cd is go into CDR mode and import all the master tracks (or stereo mixes) from all my other projects onto tracks 1&2 (L&R). however, if i do this, it doesnt really allow me to save changes in EQ and dynamic compression when passing from song to song. i've tried automix and that really didn't do anything.
the only thing i could think of would be to import all my master tracks into CDR mode and place them on different tracks, eq/compress them, and then use the mastering room to create a final master, however since the tracks in CDR mode are in pairs, this would limit me to 12 songs in the end which just doesnt seem right.
what's needed to insure that i can save EQ and compression settings on my different master tracks?
thanks!
Old 01-05-2005
jeff5xo's Avatar
jeff5xo jeff5xo is offline
Dedicated Member
jeff5xo has a reputation beyond reputejeff5xo has a reputation beyond reputejeff5xo has a reputation beyond reputejeff5xo has a reputation beyond reputejeff5xo has a reputation beyond reputejeff5xo has a reputation beyond reputejeff5xo has a reputation beyond reputejeff5xo has a reputation beyond reputejeff5xo has a reputation beyond reputejeff5xo has a reputation beyond reputejeff5xo has a reputation beyond repute
Hey Foo-bu. The only thing I can think of is what you already have thought of. What I normally do is bounce all of my tracks down to 2 (not in mastering room) Then I'll take it to mastering room and record it. Question though, why do you want to add eq and compression to your FINAL mix? Have you used the MTK effects?? They add plenty of compression and eq. Just a thought.
BOO-YA Studios
If it sounds better after EQ'ing, it works. - Massive Master
Please visit www.gravitycabs.com for a custom LIGHTED guitar or bass cab!!!!
Old 01-05-2005
Senior Member
hmm, i'll hafta try that.
i just thought that after i've done my final mix, i could fine tune things and boost the overall dynamics by adding compression. i'm kind of new at recording so maybe this isnt a common practice
Old 01-12-2005
novablue novablue is offline
Newbie
novablue is on a distinguished road
You can select the mastered (usually 23-16/24-16) virutal tracks in the track view. Then by muting all others or soloing these you can add eq and compression from the track view.
Personally I use the MTK to add EQ and use their multiband compression which is a little more useful.
Old 01-16-2005
mikey@thecave mikey@thecave is offline
Dedicated Member
mikey@thecave has a reputation beyond reputemikey@thecave has a reputation beyond reputemikey@thecave has a reputation beyond reputemikey@thecave has a reputation beyond reputemikey@thecave has a reputation beyond reputemikey@thecave has a reputation beyond reputemikey@thecave has a reputation beyond reputemikey@thecave has a reputation beyond reputemikey@thecave has a reputation beyond reputemikey@thecave has a reputation beyond reputemikey@thecave has a reputation beyond repute
Thumbs up
you mix down in the mastering room guy!!!there you insert the MTK see the effect tab click on select effect you want to insert
NEWBIES - THE ART OF MASTERING YOUR SONGS (an introduction) manning1 Newbies 46 04-29-2005 14:06
any secrets 4 using vs 1680ex... drew1 Roland, Boss, VS Series Forum 7 07-29-2003 22:54
Mixdown media for mastering from? RICK FITZPATRICK Analog Only 9 09-03-2002 09:40
Mastering - Oh no not again!! John Sayers Mixing / Mastering 14 01-22-2002 00:08
