Old 12-30-2004
msmales555's Avatar
msmales555 msmales555 is offline
Senior Member
msmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond repute
Transferring cassettes to cpu then cdrs
I would like to transfer my cassette recordings done with my Tascam portastudio MKII to CDRs. I have been trying to transfer them on to my cpu using either sound recorder or sound forge, but i end up with a lot of hiss that isnt on the tape to begin with. I need to find a way that I can avoid losing sound quality. I have a pair of RCA outputs and a 1/4" phones jack output on my recorder and I have a 1/8" input on my cpu. Im assuming that is a mono imput (should i record through the line in or the mic jack?) Is there a good way to transfer my cassettes to my cpu? or do i need to invest in a cd recorder?
Thanks so very much for any help offered!
Old 12-30-2004
DigitalSmigital's Avatar
DigitalSmigital DigitalSmigital is offline
A slice of analog pie?
DigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond repute
Double Posting
Check the TASCAM forum.
I prefer to err on the side of perfection.~ ez_willis
Old 01-04-2005
gilwe gilwe is offline
Force of Nature
gilwe is infamous around these partsgilwe is infamous around these partsgilwe is infamous around these partsgilwe is infamous around these partsgilwe is infamous around these partsgilwe is infamous around these partsgilwe is infamous around these partsgilwe is infamous around these partsgilwe is infamous around these partsgilwe is infamous around these partsgilwe is infamous around these parts
Dump to Soundforge, than use a noise reduction and maximizer plugins to compensate for hiss and level.
Old 01-04-2005
arjoll's Avatar
arjoll arjoll is offline
Force of Nature
arjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond reputearjoll has a reputation beyond repute
Connections
Use a 2x RCA male to 3.5mm stereo jack cable (should be available anywhere) and connect the RCA out of your recorder to the Line In on your soundcard. You need to make sure the levels etc are ok in the recording mixer - there's a tutorial from the main page which explains how to do this.
For basic 2 track recording there's a great little package called Acoustica (www.aconas.com) which will let you get the hang of it (from memory its a 30 day trial). No multiband compressors or such things but a good place to start.
Hope this helps! (and hope the diehard analogue people don't hate me too much for talking digital in this forum!)
Cya
Andrew
Nuendo (Hardware + Software) combo Latency and CPU Load Issues umair Cubase User Forum 7 09-03-2004 04:37
Quality Cassettes... kjbleus Analog Only 7 03-27-2004 10:21
HELP!! CPU slow down (Cubase SX user) Blues Digital Recording & Computers 10 10-14-2003 11:41
CPU temp. twist Digital Recording & Computers 3 02-09-2003 13:10
transferring cassettes to CD's beladona Digital Recording & Computers 7 07-08-2001 07:20
