Old 12-29-2004
paranoid paranoid is offline
Junior Member
paranoid is on a distinguished road
another ADA800 sync prob
I am guessing that I either have a defective BNC cable or defective units...
the PROBLEM- connected BNC WC out of EMU daughter card and connected to WC IN of Behringer ADA800, set behringer to WC slave....and wadda ya know...it won't lock! Even tried powering down the behringer and my computer even....
Am i missing a wire here or something dumb? The manual for the behringer ADA800 shows the BNC connection as using a T-connector and terminating capacitor at the Behringer end. I figured they show this as a way to explain daisychaining and how to cap it when not using any further devices....any ideas?grrr
my NEXT steps-
first-call EMU to see if i need to change something in the software (already looked and seems WC out is always present and locked with whatever the system clock is, in my case- internal 44.1khz)
second- try a different BNC cable
third- return my ADA800 for another one
fourth- return to EMU system for another one...
fifth- ditch the berhinger and go with something different
Old 12-29-2004
Track Rat's Avatar
Total Gear Slut
The destination (recorder) has to be the slave. The source has to be the clock.
Mike
Old 12-29-2004
Junior Member
wha?
so basically if i'm using the ADA800 as my pre/line in I absolutedly have to clock the whole system to it?
I thought by using the WC connection it would sync everything just fine...
Old 12-30-2004
sdsi sdsi is offline
Newbie
sdsi is on a distinguished road
I am using the 1212m and ada8000. What works for me is just setting the ada8000 to master 44k. I even have the 1212m set to internal clock and I am having a hard time distinguishing the difference between internal clock and external clock.
-Savoy-
www.iceestudios.com
Old 12-30-2004
timboZ's Avatar
timboZ timboZ is offline
Band-Aid®
timboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond repute
If you are only using the 1212m and ada8000 you don't need a clock cable.
You will only need it if you are using more than 1 adat unit to sync them together.
Old 12-30-2004
Junior Member
no solution yet...
I do not want to clock the whole system to the ADA800 because it is a lower-quality clock than in the EMU. When I run both the ADA and EMU as masters, I get pops and clicks in my audio (go figure). At this point I really think the BNC cable i have is bunk. Either that, or i may sync the behringer by using the ADAT in and clocking from the EMU's ADAT out. The Behringer WILL lock to an incoming ADAT signal, but not from the WC connection. I'm just wondering if it can stay locked to an incoming ADAT signal (no audio, just clock) while properly sending ADAT out back to the EMU.
Old 12-30-2004
PeteHalo PeteHalo is offline
Dedicated Member
PeteHalo has a reputation beyond reputePeteHalo has a reputation beyond reputePeteHalo has a reputation beyond reputePeteHalo has a reputation beyond reputePeteHalo has a reputation beyond reputePeteHalo has a reputation beyond reputePeteHalo has a reputation beyond reputePeteHalo has a reputation beyond reputePeteHalo has a reputation beyond reputePeteHalo has a reputation beyond reputePeteHalo has a reputation beyond repute
How do you know that? Have you measured it some how?
Of course you will, there's nothing unusual about that. Two digital clocks are never perfectly in sync with each other no matter how high quality they are.
How many ways to synchronize the two do you need?
BTW: Never mind, your nick explains a lot;-)
Old 12-30-2004
Junior Member
solution...yes!
for whatever reason there is "no go" on using the BNC out of the EMU into the behringrer WC in and recording through the behringer into the EMU. I tried numerous BNC cords, etc...
HOWEVER- I tried using the ADAT out of the EMU into the ADAT in of the Behringer and viola, it locked. Maybe the behringer only syncs ADAT out to itself or to the ADAT in, but not WC...
Either way, I'm rolling now, and thanks for all your ideas!
Old 12-30-2004
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
It should sync to the WC signal as easily as the ADAT input.
You mention using a BNC t-bar and terminator. If you indeed were using that, I would suggest getting rid of the BNC t-bar and connect the WC cable directly to the WC connector on the ADA8000. I've found BNC t-bars and WC to sometimes be a bit flaky for whatever reason.
But obviously, syncing to the ADAT input is just as good as WC.
Studio Clocks Dr Unedumacated Recording Techniques 9 02-07-2008 21:07
How to set up sync tracks or sync tones buddyC Digital Recording & Computers 1 08-28-2001 11:53
Here is a solution for Midi Sync with a VR800 as the Master using Cakewalk! Rish Fostex Forum 0 12-12-2000 13:32
Help on using Sync feature on a 4 track futuredays Analog Only 3 09-28-2000 17:26
