midi to usb???
ok i want to hook up my v-amp2 to a midi interface to usb....i went to radio shack and the guy said i would blow out my v-amp2 if i use usb because usb has lots of votage...is this true? heres a link to v amp if u dont know what im talking about http://www.v-amp.com/V-AMP2/index.cfm if there a way i can use the midi i have no midi interface on my computer can some one suggest a midi interface that is cheap so i can hook my v- amp2 to it?
One of several out there. Do search for "MIDI Interface"
http://www.samedaymusic.com/prodsearch?cat=2429
" Miwk Kowz " Kጝ: securelock |
Whoever told you that doesn't know what he's talking about. You should be connecting to a MIDI port, not a USB port, corrrect? USB can carry a small amount of power along with data signals, but nothing that could blow anything up...
And...
If you just want to change the effects using MIDI to the V-Amp it doesn't have anything do to with USB... Besides - they won't even plug in...
Is that what you want to do??? Just change Patches??? Are you using a sequencer with it??? I'm lost... |
Heh heh heh....
Agreed...
| Yamaha MIDI problem | doobd | MIDI Mania | 1 | 06-27-2004 14:03 |
| expansion on the midi problem | Ebicaneezer | Cakewalk / Sonar Forum | 7 | 04-11-2003 13:58 |
| The wrist bone is connected to the hand bone; help with MIDI and USB concepts/setup | f. lai | MIDI Mania | 4 | 07-13-2002 13:55 |
| Converting MIDI to WAV | AndrewSales | Cakewalk / Sonar Forum | 38 | 08-21-2001 22:31 |
| Here is a solution for Midi Sync with a VR800 as the Master using Cakewalk! | Rish | Fostex Forum | 0 | 12-12-2000 13:32 |
