Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 12-29-2004
Buzi Buzi is offline
Newbie
Buzi is on a distinguished road
Fender Strat's pickups are buzzing like crazy
hi guys...
so, I went to the store on Christmas and got me a nice Strat.
Got me a Crate amp (30w) too. Sounded sweet and all, but whenever I've got the pickup selector switch on certain positions, or if I just take my hand off the strings, the amp buzzes like a toster in a bathtub
should I get new pickups ? The ones I have are cheap white ones with the metal circles in the center...don't know what brand / model.
any suggestions ??
thanks, and happy new year!
Old 12-29-2004
sile2001's Avatar
sile2001 sile2001 is offline
_|_
sile2001 has a reputation beyond reputesile2001 has a reputation beyond reputesile2001 has a reputation beyond reputesile2001 has a reputation beyond reputesile2001 has a reputation beyond reputesile2001 has a reputation beyond reputesile2001 has a reputation beyond reputesile2001 has a reputation beyond reputesile2001 has a reputation beyond reputesile2001 has a reputation beyond reputesile2001 has a reputation beyond repute
Well, you've got a couple of things going on here. First, since you didn't specifically mention it, I will assume you got a Made-in-Mexico Strat. Nothing really wrong with them, but their pickups are known to be a little noiser than others. Second, your Crate amp is a buzz amplifying machine. Some of them sound ok, but I've never seen such amps for intensifying EMI in the pickups. Third, you might want to do a little research into how pickups work, especially when they are combined. What you will find is that when you have the selector switch at positions 1, 3 and 5, then the guitar is using only an isolated single coil pickup, which is much more susceptible to buzz. In positions 2 and 4, it is combining the signals from either bridge+middle or neck+middle, which also has the effect of cancelling some of the buzz. Fourth, the "white ones with the metal circles in the center" is what almost all Strat pickups look like, regardless of how good they are. That's just what single coil pickups generally look like.
Old 12-29-2004
ibanezrocks's Avatar
ibanezrocks ibanezrocks is offline
Unholy creation
ibanezrocks has a reputation beyond reputeibanezrocks has a reputation beyond reputeibanezrocks has a reputation beyond reputeibanezrocks has a reputation beyond reputeibanezrocks has a reputation beyond reputeibanezrocks has a reputation beyond reputeibanezrocks has a reputation beyond reputeibanezrocks has a reputation beyond reputeibanezrocks has a reputation beyond reputeibanezrocks has a reputation beyond reputeibanezrocks has a reputation beyond repute
I wouldnt blame the amp too much, I have a 30 watt crate and even at full volume with almost full gain it barely buzzes. Of course that is with humbuckers.
If it is a nice playing guitar as you said, and its just the pickups that are bad, the obvious solution is to replace them. All pickup companies make some hum cancelling single coils, so they shouldnt be hard for you to find. Then you'll have yourself a nice sounding guitar, regardless of the amp.
P.S. Theres a million solid-state amps that are worse than crate, so don't assume its that.
Turn up the good, turn down the suck
Gibson SG Standard (SD custom custom b, Gibson 490R n)
Ibanez NDM1 (Dimarzio Evolution b, SD Cool Rails m, Ibanez Infinity n)
MXR Doubleshot Distortion
Mesa Boogie Subway Rocket
Old 12-29-2004
ez_willis's Avatar
ez_willis ez_willis is offline
Virtual Ninja
ez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond repute
Shield it. It seem like a lot of work, but it's not that bad and you will be BLOWN AWAY at the difference! Go to the link below and read through it a couple of times, if you feel confident, do it yourself, if not send it to a tech to have it done. I did it myself on a squire and can't believe the difference.
http://www.guitarnuts.com/wiring/shielding/shield3.php
Old 12-29-2004
darknailblue's Avatar
darknailblue darknailblue is offline
Senior Member
Location: I'M A REDBLOODED NEW YORKER!!! thats stuck in connecticut...
darknailblue is an unknown quantity at this point
Depending on what your looking for, you might want to invest in humbucker pickups. The "cheap white ones with holes in the middle" are called single coil pickups. Humbuckers are essentially two single coil pickups in one. When you put the pickup selector on any single poisition... ie all the way towards the floor, all the way towards you and right in the middle, you are just using one pickup and since it is a single coil, that is why you are getting the hum. Humbuckers cancel this annoying buzz (I bet you play mostly distorted), which is called 60-cycle hum. I like the single coil strat sound for clean tones.... not distorted. I use a strat for a recording guitar and would never use one live. If your a rock player, you might want to invest in at least a bridge pickup, lets a seymour duncan hot rails. This way you'll get more distortion (single coils have notably less volume than humbuckers) and less noise. Humbuckers will also give you a thicker fatter sound. Or, if you like the sound you're getting but hate the hum... shield them.
~darknail
Old 12-29-2004
boingoman boingoman is offline
moldin' oldie
boingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond repute
If you are into the single coil strat sound, nothing else will do except strat style pickups. Hum-cancelling single-coils, Hot Rails, anything else doesn't sound the same. If it is a Mexi strat, some better quality strat pickups could help a lot with the noise and probly be closer to an original strat sound, too.
I just don't take my hands off the strings when the volume is up if it's too noisy.
Some shielding might help, resoldering the thing might help, turning away from your amp, getting a longer cable and moving farther away might help.
Flourescent lights, fish tanks, computer monitors, dimmer switches on lights, televisions, and analog watches with batteries are a few of the many things strat players have learned to avoid over the years.
Old 12-29-2004
ez_willis's Avatar
Virtual Ninja
Shielding WILL help, tremendously.
I just don't take my hands off the strings when the volume is up if it's too noisy. Some shielding might help, resoldering the thing might help, turning away from your amp, getting a longer cable and moving farther away might help. Flourescent lights, fish tanks, computer monitors, dimmer switches on lights, televisions, and analog watches with batteries are a few of the many things strat players have learned to avoid over the
years.
Shielding the strat will eliminate all of this. It takes about 3 hours and is not that difficult.
Old 12-29-2004
moldin' oldie
Seems like a cool site. I'm gonna try it on my strat. And in his case it may help a lot, as long as he doesn't have a bunk cable, or a wiring problem to begin with, a really noisy amp, or just a set of really noisy pickups.
Old 12-29-2004
ez_willis's Avatar
Virtual Ninja
Post the results, if possible.
Old 12-30-2004
paulmckenna paulmckenna is offline
Newbie
paulmckenna is on a distinguished road
Also, do you have any other electronic equipment near the amp? You may be getting ac hum.
Fender "Noisless" pickups? Are they shit or not? pisces7378 Guitars and Basses 15 06-06-2006 07:02
Fender "Noisless" pickups? Are they shit or not? (the shorter version) pisces7378 Guitars and Basses 5 08-11-2004 12:36
New Pickups for my Fender Stratocaster pisces7378 Guitars and Basses 2 07-23-2004 12:50
Two Fender Strats for sale alien Free Ads for Music / Recording Equipment 1 11-13-2003 06:42
Fender Lace Pickups... Self Installation, Sound differnece, and price/benifit ratio?? pisces7378 Guitars and Basses 6 04-22-2003 23:24
