Old 12-29-2004
anywhither anywhither is offline
Junior Member
anywhither is on a distinguished road
why a better D/A converter?
I have been using 828mkII for some while.
recently get curious about converter.but something I don't understand.
I know a high end A/D can make the signal quality better into a mix in pc,esp. compare with the one in 828.
does it mean Digital to Digital connection won't have loss affection?
and I heard somebody uses a better D/A (benchmark DAC1) with 828.why is it for?only connect the D/A with a pair of monitors or something?if yes,how difference using the MAINOUT in 828?
last question,if after I get both High end A/D & D/A,should I also change other audio interface instead of 828?
Old 12-29-2004
Teacher's Avatar
Teacher Teacher is offline
do unto others......
Teacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond repute
A better DA allows you to hear things more accurately so you can make better decisions when tracking(i e mic placement etc.) and mixing.
If you get a better AD and DA you don't need to get another interface I don't see why the MOTU won't be fine unless you don't like it?
"...if the opposite of pro is a con lets go beyond this, the opposite of CONgress must be PROgress..." Cage
Old 12-29-2004
Scinx Scinx is offline
Mechanical Monkey
Scinx is on a distinguished road
Or is an extreme and concise nature - how good will your recordings be if you were deaf?
Old 12-29-2004
Fletcher's Avatar
Fletcher Fletcher is offline
Force of Nature
Fletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond repute
The resoulution and stereo field of a better D/A converter will give you a better idea of what has been recorded. It's part of the monitoring chain.
A chain is only as strong as it's weakest link... so, in other words, you can have the greatest monitors in the world, but if the signal you're sending to those monitors is compromised then the monitors are compromised. If you have less than the greatest monitors in the world you're going to experience a double whammy... you'll be sending a crap signal to crap monitors which will often cause you to over EQ, over effect, over process your music in an attempt to compensate for a crap monitoring chain.
It's kinda like trying to play guitar with an amp that you can't hear... yeah, you know where the chords are, you know that you're playing the chords in the right spot, but you'll have no idea of how to approach the instrument 'touch' wise... so while you'll be able to go through the motions, you won't be affored the opportunity to do your best work.
Fletcher
Mercenary Audio
mwagener wrote on Sat, 11 September 2004 14:33
We are selling emotions, there are no emotions in a grid
Old 12-30-2004
Junior Member
thanks all of you!I understand it now.
what about these 2 D/A do you guys think?
BENCHMARK DAC-1
LUCID D/A 9624 Stereo 96k
I only need 2 outputs for stereo mixing to connect with pair of monitors.
is that LED ladders in LUCID for master vol's signal?
if yes,that is cool.I really want to have it to control the master level.
I always doubt when I will blow up my monitors using MAIN's vol Knobs in 828 without any signal level display.
can those headphone out run a 250ohm headphone?
the one in 828 is not enough,signal becomes weak,even the headphone amp in Voicemaster Pro is better than 828.
or there are more choice out there?
Old 12-30-2004
Teacher's Avatar
benchmark dac-1 I believe has a headphone out and you can control the volume I THINK...i don't have one personally. If not you can always get this little gem
http://www.frontendaudio.com/A%20Designs%20ATTY.htm
its a passive line attenuator works GREAT to control the signal level
Old 12-30-2004
ozraves ozraves is offline
1K Silver Member
ozraves has a reputation beyond reputeozraves has a reputation beyond reputeozraves has a reputation beyond reputeozraves has a reputation beyond reputeozraves has a reputation beyond reputeozraves has a reputation beyond reputeozraves has a reputation beyond reputeozraves has a reputation beyond reputeozraves has a reputation beyond reputeozraves has a reputation beyond reputeozraves has a reputation beyond repute
I like the Lucid DA9624. The Kurzweil Rumour lacks the connectivity of the Lucid but is a nice unit as well.
Steven
Mojo Pie
Gear reviews, forums and blogs
Old 01-08-2005
Richard Monroe Richard Monroe is offline
Been Here, Posted That
Richard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond repute
The Lucid rocks.-Richie
Old 01-08-2005
Fletcher's Avatar
Force of Nature
The DAC-1 does have a volume pot for the headphone out... as for the "ATTY" we have one on the 'shop stereo'... the taper of the pot is all wrong for use in a studio. The first 3rd of the pot's throw nets little result, the subsequent 1/2" of throw will take you from 40-100 in a heartbeat... the last 3rd of the throw might as well just be shades of "full open"... damn frustrating little box... but the 'panic mute' switch can come in handy when the phone rings.
Fletcher
Mercenary Audio
Old 01-09-2005
Warhead's Avatar
Warhead Warhead is offline
Jai guru deva om
Warhead has a reputation beyond reputeWarhead has a reputation beyond reputeWarhead has a reputation beyond reputeWarhead has a reputation beyond reputeWarhead has a reputation beyond reputeWarhead has a reputation beyond reputeWarhead has a reputation beyond reputeWarhead has a reputation beyond reputeWarhead has a reputation beyond reputeWarhead has a reputation beyond reputeWarhead has a reputation beyond repute
Agreed. Lucid converters are a huge step up over most. I use them on A/D and D/A now and they're a great unit with tons of headroom as well.
War
Warren Dent
www.ZenProAudio.com
That's right....a new location for me!
Old 01-09-2005
justharold justharold is offline
Senior Member
justharold has a reputation beyond reputejustharold has a reputation beyond reputejustharold has a reputation beyond reputejustharold has a reputation beyond reputejustharold has a reputation beyond reputejustharold has a reputation beyond reputejustharold has a reputation beyond reputejustharold has a reputation beyond reputejustharold has a reputation beyond reputejustharold has a reputation beyond reputejustharold has a reputation beyond repute
Because they're better.
And better is always...well...ummm..."better". (Until, of course, you come upon someone who has something even BETTER. But...we won't talk about that right now...)
  #12
Old 04-20-2006
peritus's Avatar
peritus peritus is offline
"The Fountainhead"
peritus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond repute
Old thread.. So I'm threadjacking without guilt...
Disclaimer... I'm currently making a move up the food chain.. I guarrantee there are things that I am misunderstanding... beware...
I'm not asking this question from a serious purchasing perspective.. but... Is it safe to say that my monitoring would sound better using the DAC-1 for output, instead of the output channels of a Digi 002?
Would it even possible in PT to select the DAC-1 for output?
Wait.. I guess I would just go out from the Digi S/PDIF.. and into the DAC S/PDIF...
Thoughts??
P.S. Also, how might I use it in conjunction with a Mackie Big Knob?
Thanks..
Joshua Dotson, Peritus Sound
SoundClick
  #13
Old 04-20-2006
BigRay's Avatar
BigRay BigRay is offline
I hate jambands.
Location: Southeastern NC. No more Krauts and Bad music.
BigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond reputeBigRay has a reputation beyond repute
dont rule out mytek. I like their products much more than benchmark. cheaper too, IIRC. I use them for ADC and D/A
teddy
BENCHMARK DAC-1
  #14
Old 04-20-2006
kenoflife kenoflife is offline
Newbie
kenoflife is on a distinguished road
Black lion mod?
How about doing the Black Lion mod on an 828MK2 ?
According to Matt, the man doing the mods, once modified, that MK2 will compete quite well against RME, Metric, etc., and you'll find that its two mic preamps are quite nice. The modification covers all of the analog stages--all the inputs, outputs, mic preamps, and headphone amps.
I assume this means the A/D and the D/A convertors...
See:
http://www.blacklionaudio.com/motu_firewire_mod.html
What d'yall think?
  #15
Old 04-21-2006
Phuturistic Phuturistic is offline
Junior Member
Phuturistic has a reputation beyond reputePhuturistic has a reputation beyond reputePhuturistic has a reputation beyond reputePhuturistic has a reputation beyond reputePhuturistic has a reputation beyond reputePhuturistic has a reputation beyond reputePhuturistic has a reputation beyond reputePhuturistic has a reputation beyond reputePhuturistic has a reputation beyond reputePhuturistic has a reputation beyond reputePhuturistic has a reputation beyond repute
See:
What d'yall think?
I got an appointment to get my 828mkII modded in May. The mod covers all analog stages and a new clock thats supposed to lower jitter from 120 picoseconds to less than 10.
Harmonics from D/A converter. Normal? Industrial Digital Recording & Computers 0 03-31-2004 01:15
Lucid ADA1000 A/D and D/A converter soundcard q boymonkey Digital Recording & Computers 2 09-08-2003 11:43
A/D D/A converter upgrade thoughts Michael Jones The Rack 9 07-06-2003 16:13
A/D D/A converter Atipp Recording Techniques 3 03-18-2002 07:20
20bit vs 24 bit, how big is the difference? chambers Recording Techniques 58 07-19-2001 23:35
