Alesis Qs-6: Dead Key
I have a key that does not make a sound when hit. I believe it is the B3. I took the keyboard apart, and if I tap the little rubber buttom with my finger it works. I believe the button has has lost some of it's sensitivity though, because when the key comes down it does not work. Has anyone has this problem? Do you know how to fix it or if not, how much it would cost to have fixed? Thanks. -Perry
Never had that problem and I've had mine for years. Bought new when it first came out. May need to have it looked at or replace that pad? Wish I could be more help.
Ben ![]()
Unwanted e-mail = SPAM on the internet (not legal) Infomercials = SPAM on the airwaves (Legal) Junkmail = SPAM in your mailbox at home (Legal) Check Out My Tunes |
My Korg N364 had this problem. I removed the pad from the cicuitboard, and simply rubbed the contacts inside with my bare fingers and reinstalled (mine were simply pressed into the Circuitboard via rubber tabs molded into the rubber strip). I would recommend any type of abrasive or cleaning product as the contacts themselves inside are of a rubbery consistency (Hence the aftertouch), a simple rubbing with the fingers should be enough to rough up the contacts, and remove any dust. And while you have it apart a good dose of compressed air will help. If this doesn't work be sure to inspect the key itself for physical damage which may prevent it from properly striking the contact. Good Luck!!!
Torment, Violent Aggression, Systematic State of Oppression. The Heretics, All Swing From The trees, Cast To Hell, With Their Disease. DARKENED |
I had that problem with half the keyboard on my old Korg X5D after a band member...er...FORMER band member spilled a generous helping of budweiser all over the top two octaves.
I pulled off the rubber pad, soaked the pad and used a toothbrush to clean off the circuit board and it worked good as new. Saved some money, lost a band member. =)
TROG-DOOOOOOOR!!!! www.rayjonesspecial.com www.a440studios.com |
| do mo'phatt s . . . . | InfiniteMH | Keyboards and Sound Modules | 13 | 06-28-2003 15:02 |
| Speaker simulations for Alesis M1 active Mk2 | Boray | Roland, Boss, VS Series Forum | 3 | 01-09-2003 12:19 |
| Alesis RA 100 or Hafler P1500? | geekgurl | The Rack | 13 | 12-07-2002 11:32 |
| Alesis Service Department: Mnicoletti?? | MOFO Pro | Alesis Forum | 6 | 08-02-2001 21:59 |
| Roland pad-8, Alesis D4, and software hell | jthomas | MIDI Mania | 0 | 08-01-2000 19:38 |
