Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 12-24-2004
werewolf831 werewolf831 is offline
Senior Member
werewolf831 is infamous around these partswerewolf831 is infamous around these partswerewolf831 is infamous around these partswerewolf831 is infamous around these partswerewolf831 is infamous around these parts
i need help retubing a Marshall TSL602 combo
Does anyone have experience tun=bing one of these or a similar amp?
Right now I'm only changing pre amp tubes. There are three preamp tubes in a row on a metal strip, and the last one (furthest from the power tubes) has some kind of metal tube over it and I can't figure out how to take it off! Why is this tube covered? Also, wondering if this may be the phase inverter, or if the phase inverter is the preamp tube right next to the power tubes.
Thanks for the help.
werewolf
Old 12-24-2004
Hard2Hear's Avatar
Hard2Hear Hard2Hear is offline
Retired from Audio
Hard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond repute
Hi!
I don't have that amp but I can take a couple educated guesses for you.
Either you push in and twist on the cover and it will come off, OR it's not a tube at all, but a capacitor and it should not be removed. Sometimes these look the same, and on some amos they're right next to each other. If I had a schematic of that amp I'd tell you, but I don't. If you twist on the cover ever so gently and it doesnt move, it probably isnt a tube cover.
Hopefully someone else may own that amp and be able to tell you.
H2H
Old 12-24-2004
Senior Member
I was able to take it off. Pushed in and twisted it off and there was a tube in there. This cover had a little spring inside of it. It wouldn't have anything to do with reverb would it? I'd still like to know what this cover is for.
I'm just going to assume that this covered tube is not the phase inverter since it's furthest from the power tubes.
Thanks for the reply H2H.
Old 12-24-2004
Senior Member
Another question, same topic.
I know it's best to have an amp rebiased when changing power tubes. BUT, is there any danger in taking out the old power tubes to clean the pins with contact cleaner and then put them back in? I noticed the preamp pins were absolutely filthy. I imagine the power tubes are just as bad.
Old 12-24-2004
Hard2Hear's Avatar
Retired from Audio
On some amps all the pre amp tubes have those covers. The only purpose for the spring it to hold the cover on well for the "push and twist" thing and so it doesn't rattle. The covers themselves act as heat shields mostly. Though I have ran amps without them at all and not hurt a thing. I'm kind of suprised that there was only one cover, usually they're all covered, or none covered.
As far as which is the phase inverter, it's hard to tell without a tube schematic. Maybe they have those on their site? I dunno.
H2H
Old 12-24-2004
Hard2Hear's Avatar
Retired from Audio
there is no danger in pulling out the power tubes. You won't mess up the bias.
Just make sure it's unplugged and turned off.
H2H
Old 12-24-2004
Le Basseur Le Basseur is offline
Junior Member
Le Basseur is on a distinguished road
The metal cover's purpose is SCREENING that tube.This is the main issue (because the first tube is the most critical regarding external influences) but such a cover helps as well on reducing microphonics and cooling the tube in question.
If your amp has that "bayonet" shield on the first tube only,that's it....the engineers thought that there's no need to put shields on the others.Still,I'd look at the shape of each small tube's socket:including the first one,do they have the same metal collar around the base?In this case,the amp was initially provided with shields on all smaller tubes,but someone got them off and forget the shields somewhere,except the first tube!
Yes,your assumption is correct:the farthest tube from the outputs is in most cases the input tube (gain).The PI tube is the closest to the outputs,due to a logical signal path.
About the pin cleaning,please DO NOT,for any reason,use something like you said you'd use (contact cleaner) for cleaning!
The point is that this kind of stuff goes for pots,switches or whatever what's supposed to work at ambient temperature.Tube's pins are,thermally,another story....they heat together with the tube and,even if they don't reach the bulb temperature,any of those chemicals used for cleaning will caramelize there.This means a poor contact and more trouble in the future.
You can clean the pins with isopropyl alcohol (the one wich is evaporate fast and doesn't leave any traces of water),the same alcohol we used two decades ago for cleaning the magnetic heads on our beloved reel-tracks.
About bias,yes,it's safe to get the amp to a tech for that operation (it's a must if you changed the output tubes and it should take only a few minutes).
Regards,
Old 12-24-2004
Junior Member
Originally Posted by Hard2Hear
Though I have ran amps without them at all and not hurt a thing. H2H
You forget to mention WHAT amps you ran without those shield cans.
I wouldn't try that on a medium-gain (Mesa,Acoustic) or hi-gain (Soldano,Peavey 5150),especially if the amp in question is cranked!
Old 12-24-2004
Hard2Hear's Avatar
Retired from Audio
I hate mesas and I TOTALLY HATE Soldanos. But I did run my Soldano without the shields while I was experimenting with different pre amp tubes in it. I didn't notice any extra noise or added microphonics when I did it. Mostly I have removed the covers from Fenders, cause I have owned about 15 Fender tube amps. I do it when changing around pre amp tubes all the time. Its a PITA to put them back on when swapping in and out. I always put them back on when I'm done, mostly because I'd lose them if I didn't.
But don't you find it interesting that there was only a cover on ONE of the pre amp tubes? I would think they all had covers at one time.
H2H
Old 12-24-2004
Senior Member
Wow, good info.
FYI, I bought this amp about 4 yrs ago from Musicians Friend "scratch and dent" section. Never had any problems, and yes only one tube cover. Mind you, I only use this amp at home and the Master volume rarely gets cranked past 3. Although I do crank up the channel volume.
As for the contact cleaner, it's too late. I already used it. I got the idea from the Eurotube websites FAQ. Here's a quote.
"It's also a good idea to clean the tube sockets before installing new tubes. This can easily be done by spraying contact cleaner on the pins of one of your old tubes and working the tube in and out of each socket a few times. Do this for both preamp and power tubes."
After reading some posts here, I've seen several people recommend Isopropyl alcohol as well. Think I'll go this route next time.
Old 12-24-2004
Senior Member
The first preamp socket had a metal base with two notches for inserting the metal collar. The other three preamp sockets had round black plastic bases.
  #12
Old 12-24-2004
Junior Member
I wasn't talking about tastes....
OK,I got that...but,again,how much you cranked the amp when tested it and FOR HOW LONG?
Take my word,mate....and leave the shield cans where they're supposed to be in such amps.
Most Fenders really don't have a problem functioning without shield cans mainly because they have moderate gains and respectably high anode voltages on gain stages.
Yeah,tell me about it....
As I said,if the brand's engineers didn't think they're a must everywhere,they made the amp this way,with the first tube "canned" and the others FTA ("free-to-air").Think on that as another way of making a specific amp "economically suitable".
The Marshall in question is one of the countless amps having only the first tube shielded that I saw or played or repaired.
Cheers,
  #13
Old 12-24-2004
Junior Member
Gee,you're fast...and impatient!
I don't have nothing against Eurotube guy but he's slightly supperficial here.
I say,unplug your amp NOW!!!!! and clean the pins with alcohol.
There might not be "the route for the next time"!
To be more specific,the FAQ issue you quoted is a amateurish way of making old,oxidated tube pins and socket contacts to work again.The "contact spray" stuff helps only in a mechanical way but it doesn't CLEAN the garbage.
A side effect of the "contact spray" is that it's chemical agents could easily destroy your small tubes (their pins come directly from the glass).I saw enough 5-stars premium ECC83's destroyed in no-time just because the owner(s) did exactly what you did...a "contact spray" is a mildly agressive chemical stuff that will corrode slowly but surely the pins protruding the glass envelope.Once that this happens,the tube looses it's vacuum and eventually cracks lamentably "for no reason".
Take care!
  #14
Old 12-24-2004
Junior Member
OK,than that's it...your Marshall has ONLY the first tube shielded!
Really,there's no problem with that.
Cheers,
  #15
Old 12-24-2004
Senior Member
Thanks for the advice, I'll be sure to clean those tubes off.
I read on one of your older posts that you didn't care for JJ tubes on Marshalls. Were you only speaking of power amp tubes or preamp tubes as well? This amp already has c-winged Svetlana's in the power tube section, but the stock pre's consisted of thre Ei's and one svetlana.
  #16
Old 12-24-2004
Junior Member
About the preamp tubes,put the C-winged Svetlanas on work.They're the most "Marshally" money can buy as modern production.The same applies to output tubes (JJ's are more on the Fender's side).
About the three EI's you mentioned....keep them as spares but don't EVER rely on them.Beginning from the early '80s,EI factory has major QC problems and their small tubes are known as very microphonic.Eventually,due to the very poor quality materials involved (mica spacers and isolations inside the tube),an EI ECC 83 becomes microphonic in less than 100 hours.
Have fun,
  #17
Old 12-25-2004
gusfinley gusfinley is offline
Senior Member
gusfinley has a reputation beyond reputegusfinley has a reputation beyond reputegusfinley has a reputation beyond reputegusfinley has a reputation beyond reputegusfinley has a reputation beyond reputegusfinley has a reputation beyond reputegusfinley has a reputation beyond reputegusfinley has a reputation beyond reputegusfinley has a reputation beyond reputegusfinley has a reputation beyond reputegusfinley has a reputation beyond repute
do yourself a favor............
Luckily the TSL series are easy to bias yourslef - If you know how to read voltage on a multimeter then YOU can do it (or a freind who knows how and you trust)
I have the info for the DSL series, but that won't really help you much. Search around on the net and I'm sure you can find the bias info for the TSL series.
  #18
Old 12-26-2004
donkeystyle donkeystyle is offline
This place sucks now. Bye
donkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond repute
the tsl's are a fixed bias..........well that's what my friend was told when he went to get his amp biased.
This place is garbage.
FYI - Thinking of getting a Marshall mic - you need to read this! bvaleria Microphones 30 10-05-2005 08:16
Price of a Used Marshall Combo Amp arcaxis Guitars and Basses 2 10-17-2003 23:19
Mxl 603 Bobalou Microphones 5 10-05-2003 00:12
MXL2001 vs MXL V67G Wannaplay Microphones 20 07-03-2003 06:08
Marshall Electronics Mics - Beware bas1236 Microphones 56 05-22-2002 19:12
