Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 12-24-2004
pdlstl pdlstl is offline
Your daddy...
pdlstl has a reputation beyond reputepdlstl has a reputation beyond reputepdlstl has a reputation beyond reputepdlstl has a reputation beyond reputepdlstl has a reputation beyond reputepdlstl has a reputation beyond reputepdlstl has a reputation beyond reputepdlstl has a reputation beyond reputepdlstl has a reputation beyond reputepdlstl has a reputation beyond reputepdlstl has a reputation beyond repute
Total MIDI newbie with question.
I've been recording digital audio for 3 years. I recently decided that I would like to dabble in MIDI.
I have:
Yamaha P60
M-Audio 61es
Native B4
The Grand
I finally was able to play and record in SONAR 4PE for the first time tonight.
However, when I would choose a "preset" in B4 and play it, I could hear the vibrato, rotation etc. But the minute I hit "record", all of those effects were gone. And when I played it back, I had to turn them all back on.
What gives?????
TIA
Old 12-24-2004
James Argo's Avatar
James Argo James Argo is offline
Fancy Rock N' Roll
James Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond repute
Lightbulb
Hi, pdlstl
To "record" B4, you need one MIDI track, and one DXi track (or audio track with B4 DXi in the effect field). Set MIDI track output routed to B4 DXi track, select channel 1, bank, patch, etc as you want on the MIDI track instead of bank and patch in B4. Your MIDI track is going to control B4 track, so if you do select bank and patch in B4, your MIDI track will force B4 to it's setting when you playback. Therefore, B4 will be reset.
Actualy, you don't record B4 but MIDI data into MIDI track which is routed to B4. Once you've done recording & editing MIDI track, select both tracks (MIDI and B4 DXi track), then click Edit menu, and hit Bounce to track. This process will "print" the MIDI as played by B4 into new audio track (result).
Jaymz
Keep Rockin' and Rollin'...
Old 01-04-2005
Riverdog's Avatar
Riverdog Riverdog is offline
Registered User
Riverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond reputeRiverdog has a reputation beyond repute
Just a thought...
I also think that when you press record - your recorder resets your "MIDI Controller Data" to '0' which kills all the effects...
This is a common (non-broken) process for most all MIDI Recorders...
Total Newbie Luddite Question. sixchannel Cool Edit Pro / Adobe Audition Forum 9 12-17-2003 14:06
I have a TOTAL newbie question... chrisharris Cool Edit Pro / Adobe Audition Forum 14 12-13-2003 21:21
Sonar 2 MIDI Envelope Question zone_ahead Cakewalk / Sonar Forum 0 03-28-2003 01:49
Midi Question Digital Performer Jeroleen Digital Recording & Computers 0 01-05-2002 21:46
Converting MIDI to WAV AndrewSales Cakewalk / Sonar Forum 38 08-21-2001 22:31
