VS-2000CD Volume Issue
I am wondering if anyone is having problems with the volume of the mastered CD being lower than normal. When I play it on a regular CD player after a commercially recorded CD the volume is much lower. I can find nothing in the manuals to adjust the volume. Any suggestions?
Also, I notice that my condensor microphone is clipping at a lower volume than any other another inputs. When I adjust the input to stop the clipping it is at a lower volume than the other inputs. Any ideas on this one? |
Haven't got that far yet. My neighbor has mine in his studio tonight and is messin' with vocals. So I'll see what he finds.
Thanks...After reading around, I guess the right term is that the CD needs to be hotter. I've tried some other things but still no success.
Hey Dennis. When you set up your gain stage, do you get the pre-amp as hot as you can? What I do on my VS is turn the pre-amp till the red light comes on and then back it off just a bit. You may already know this, but you need to get it as hot as possible without clipping to tape. You'll never get your cd as hot as professional cd unless you send it off to a mastering house, but you should be able to get acceptable levels. If your gain stage is good, then you might have a problem with your machine. Also make sure your master fader is always set to unity gain.
BOO-YA Studios If it sounds better after EQ'ing, it works. - Massive Master Please visit www.gravitycabs.com for a custom LIGHTED guitar or bass cab!!!! |
If you really want some good VS advise, go here...
Home Rec is a great general purpose forum, but for Roland VS Specific stuff, you can't beat the vsplanet.
http://www.vsplanet.com/cgi-bin/ubb/ultimatebb.cgi Good luck.
Ben http://www.soundclick.com/benwalter |
Jeff...Thanks for the info. I'll give that a try. I've heard that Sound Forge can get the volume close to commercial levels. I'm doing my home work on that now.
Ben is right too, definitely check out VS-Planet. It's a great website to help with your VS!
| Volume Control? | Foxdog175 | Recording Techniques | 8 | 06-25-2004 09:30 |
| volume envelope(s) | welldonep | Cool Edit Pro / Adobe Audition Forum | 12 | 01-14-2003 17:16 |
| Delta 66, Sonar and General Volume Questions | mayan | Digital Recording & Computers | 0 | 01-18-2002 09:41 |
| Volume level: mixing vs. mastering | secretorchard | Mixing / Mastering | 3 | 11-23-2001 00:47 |
| Volume problems in cakewalk | ray74 | Cakewalk / Sonar Forum | 13 | 12-14-2000 02:39 |
