phantom power not making it thru wallplates
So I finally got around to soldering my wall plates. I just finished channel 1, plugged in a sm-57 to the iso room side , and connected the other end of the wall plate to my mixer. Works fine. Then, I go to attach my mxl v67. Nothing. I know the mic works, becuase it will work when I connect it directly to my mixers preamps. Any ideas why my wire isnt carrying phantom power?
when the dust all settles and all of us have gone our life ways, the only thing anybody will care about in those recordings is the content. The songs and how they are performed. - SouthSIDE Glen |
Or they are wired wrong. |
I've run phantom power through a 100' snake with no problem. Do you have a multimeter to test with?
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music. __________________ "Do yourself a favour just shut up, read up then put up." --muttley600 |
no multe meter. The cable is only like 4 feet long, and is quad cable. I am almost sure everything is wired up right, how else would all my dynamic mics work?
Is it possible you got your + and - wires backwards? In that case the audio signal would just be 180 degrees out of phase but your DC voltage (phantom power) would be backwards and your condesor mics wouldn't be getting the power they need. Dynamic mics would still work.
I'm not a mic expert but that would be my guess. |
It's worth checking your connections again. |
Before you give yourself a troubleshooting headache, unplug the mic from the far away patch panel, and plug it directly into the console, into the same jack that the patch bay was attached to, and make sure the mic works as well as that input channel.
While unlikely that the mic or the input channel went pfffffft-pop, it's a simple test you can do just to be sure. Then dissect your wiring if the mic works fine directly on the input channel. and MsHilarious is correct, +48V should be on both the + and - phases of the microphone cable. If its out of phase, the microphone should still operate, if the ground is wired on the console side. This is how the phantom voltage goes back. ![]() ![]() |
When I wired up my wall plates, I tested them before installing them into the walls.
As I was doing new construction, this was simple to do. I'm guessing you have something wired up wrong. If you're doing a lot of connections, its easy to get things mixed up. |
all my wiring is correct, and I actually had that chart when i wired it all up
any other ideas?
Did you try plugging the mic directly into the same input channel on your mixer?
If that doesn't work, you know something is dead either in the mic, or the console. If it works, it IS your wiring. |
So??? What was it?
| phantom power question....mixed mics | kensington | Microphones | 8 | 11-02-2004 08:10 |
| Using Phantom Power | Mr T | Recording Techniques | 2 | 09-12-2004 04:08 |
| a fairly boring compressor question, concerning phantom power. | Rassoodocks | The Rack | 6 | 07-04-2003 18:11 |
| What is the noise floor on your Delta? | canada-paul | Digital Recording & Computers | 30 | 05-27-2003 06:59 |
| Phantom Power Question | King Elvis | Microphones | 4 | 03-14-2002 07:40 |
