I've started using a Roland GI-20 midi controller connected to a PC via USB. I use a Roland GK2h 13-pin pickup mounted to an older strat (heavy, no trem). I record midi using Cubase VST triggering VST Intstruments. All is well, except for a terrible ground hum when I connect the GI-20's guitar out (standard 1/4" audio out) to either a live amp or my PA. My short-term solution has been to not use that jack, but rather to connect the guitar's standard 1/4" input directly to the amp or PA mixer, i.e. bypass the GI-20's standard instrument path altogether. I have tried ground-lifting all but the computer, to no avail. (the monitor is an LCD, by the way). I've tried separating the guitar amp's AC outlet and putting everything else on one circuit - no luck.
Next I'll try connecting all power cords to just one AC outlet. Can anyone think of anything else? Thanks, STeve |
I'm late in my reply to this topic but....
I've started to use this and have found the same problem. Have you any better solution after all this time?
7 times down, 8 times up......
| electrical noise killing my recording! | doughulin | Fostex Forum | 4 | 08-15-2004 16:50 |
| Noise Reduction -- removing backround noise | welldonep | Cool Edit Pro / Adobe Audition Forum | 10 | 01-13-2003 14:47 |
| Noise Noise Noise!!!!!! How do I get rid of 60Hz hum? | nemal | Recording Techniques | 12 | 11-29-2000 09:44 |
| Building snake cable. | kristian | Studio Building & Display | 1 | 10-31-2000 10:23 |
