Old 12-16-2004
karambos2's Avatar
karambos2 karambos2 is offline
Junior Member
karambos2 is on a distinguished road
Aux sends feeding the cue mix
Up to now, I've been communicating with the tracking room via the PHONES socket on my Behringer Eurorack MX2642A
However, I'm aware that some (most?) people cue using the aux sends. But the aux sends on my desk are mono i.e. when I plug my headphones into one of the aux sends, it only comes through in one ear. Whereas the PHONES socket is stereo.
Am I to take it that when creating a cue mix using aux sends, you need a seperate mixer in the tracking room in order to be able to have a stereo mix?
What if you had two musicians each needing a headphone mix but one wanted, say, more guitar/less vox and the other more bass/less guitar?
Mac G4 dual 1GHz Mirror Door Drive, 1.25GB RAM, 140GB drive, OS10.3.6
LOGIC Plat 6, Audiowerk 2 card
200MB allocated to LOGIC
www.thefair.de
Old 12-16-2004
deepwater deepwater is offline
1K Silver Member
deepwater has a spectacular aura aboutdeepwater has a spectacular aura aboutdeepwater has a spectacular aura about
You need a headphone amp
Grace m902 $1,595.00
http://www.musiciansfriend.com/srs7/...se_pid/180147/
Behringer HA4700 $109.00
http://www.musiciansfriend.com/srs7/...se_pid/240107/
ART HeadAMP $49.00
http://www.musiciansfriend.com/srs7/...se_pid/180615/
Presonus HP4 $99.00
http://www.musiciansfriend.com/srs7/...se_pid/184128/
The most popular HR member - just do a search
Old 12-16-2004
peopleperson's Avatar
peopleperson peopleperson is offline
I'm so sorry.
peopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond reputepeopleperson has a reputation beyond repute
Yep, you do indeed need a headphone amp. You can feed it a stereo signal, and it will generally split this stereo mix into a handful of headphone outputs. There's probably an easier way, but I use two aux sends (left and right) for a stereo send. If you need multiple mixes into the record room, you may need more than one headphone amp, or maybe there's one out there that'll take more than one stereo mix and distribute it somehow.
Here a douche, there a douche, everywhere a douche douche.
Old 12-16-2004
1K Silver Member
Hrere are a few options for headphone mixes
Option 1: The best is an Aviom system which takes 16 direct inputs and sends them out via CAT5 cable to each persons personal mixer. This can run around $1500.00 for a basic setup
http://www.aviom.com/
Option 2: Oz Audios Q-Mix HM-6 It features six easily controlled, independent headphone mixes from five sources, plus effects $299.99
http://www.musiciansfriend.com/srs7/...se_pid/483861/
More Volume on CD Master? MONTE Mixing / Mastering 12 02-13-2005 21:04
Mixing Tips from Harvey Gerst and the ubiquitous Mixerman (R.A.P. regulars) Blue Bear Sound Mixing / Mastering 6 03-01-2001 19:34
VStudio CD Burner jpryor Roland, Boss, VS Series Forum 4 01-12-2001 08:06
