Go Back   Home Recording > General Discussions > MP3 Mixing Clinic
Old 12-14-2004
gtrman_66's Avatar
gtrman_66 gtrman_66 is offline
Dedicated Member
gtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond repute
Just the tracks
Hi y'all,
I have been lurking around reading this board for a while, so I thought I'd jump in and post something.
I'm in the very final phases of recording a CD that is going out to be mixed the first week of January. I thought it might be interesting to post a rough static mix of just the bare tracks and then maybe come back and compare the final product after mixing a few weeks from now.
This is called "Girl Across the Street". All tracks were recorded with no compression or EQ applied, just bare and basic.
Thanks in advance for the listen!
http://strmkr0.tripod.com/sitebuilde...girl_12_13.mp3
Old 12-14-2004
Scriabin's Avatar
Scriabin Scriabin is offline
I'm not a crook
Scriabin is on a distinguished road
Hi there,
Welcome aboard the site, I've been here for a while now. Soak up as much knowledge as you can here. There's alot to be learned and don't forget about gearslutz.com or recforums.prosoundweb.com either.
Now on to the song.The bright side is you've got decent tracks to work with. The first thing that comes to mind is the need for panning. It seems like everything is competing smack dab in the middle. Reserve the middle for lead vox and bass. The secret to a great mix is hard panning. Its not uncommon for me to usually pan rhythm guitars hard left and right. Drums are usually spread across the stereo field. Pan those keyboards to opposite sides and spread out the bg vocals hard to.
I enjoy the song and there is some good playing there. However, youll need some light compression for the lead voice maybe 4:1 with about 3-5 dbs of
reduction. Youll have to fool with the attack and release to get it to sit right.
Fight the urge to reach for the EQ. Pan everything judiciously, adjust the volume levels, and ignore the computer screen. Monitor with your ears and use eq to carve out spaces for instruments that are masking others.
Good luck
Old 12-14-2004
gtrman_66's Avatar
Dedicated Member
Thanks for listening.
I haven't even attempted to mix these, they are going out to be mixed so I just kind of threw them up there to get some ears on the tracks. I recorded stereo tracks on just about everything, not that everything is going to wind up that way in the mix, but so the options are open to either mix an instrument to mono or pan it out stereo. Right now I just have the guitar, piano and hammond panned out to different degrees of left and right.
Glad to hear the tracks sound good though, I am going to try and post the result next month after the mix/master is done.
cheers
Mixing strategies for stereo tracks? petimar Mixing / Mastering 8 05-29-2008 13:20
need help with V tracks on BossBR8 soundmaster Roland, Boss, VS Series Forum 10 01-31-2006 18:31
Can you drag tracks freely in Acid XPress? matt's bedroom Newbies 4 06-08-2003 14:45
Mastering Sonar tracks in Wavelab then to CD 4ever Cakewalk / Sonar Forum 5 09-24-2002 11:42
9 Drum Tracks in Two Days... remote drum recording... Blue Bear Sound Recording Techniques 58 03-01-2002 07:15
