Old 12-13-2004
Derrick111 Derrick111 is offline
Newbie
Derrick111 is on a distinguished road
Best Place To Get 1/4 Inch Reels For Low $$
Hello, I just got a 1/4 inch reel-to-reel 8 track recorder. What is the best place to get tapes for lowest $$$$? I will also want cheap tapes for low $$$$ for quick sketching ideas and demo. I remember Apex being the best (?) and now they are gone but Quantegy bought them out (?)... Do I have this right? Anyhow, where do I get cheapest price on quality tapes and not so quality? What tape number should I get?
THANKS!!
Derrick
Old 12-13-2004
The Ghost of FM's Avatar
The Ghost of FM The Ghost of FM is offline
French Mofo
The Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond repute
If we are talking about the Fostex A-8 here, Ampex/Quantegy 456 would be your best choice for your serious productions and Ampex/Quantegy 457 or 407 would be fine for your slightly less serious projects.
Quantegy took over the reins at Ampex back in the late 90s but remained in the same factory, making identical products to what was in the Ampex catalog at that time. It's really just a name change more then anything else. It's also a way of discerning older stock from newer stock too and if your buying second hand tape for goofing around with, beware of Ampex tape made from 1995 or older as it will likely need to be baked in a dehydration oven for an hour or two to dry back the binder glue that holds the oxide layer to the base layer of the tape. Otherwise, you will gum up your heads with a very sticky messy goo also known as SSS or Sticky Shed Syndrome!
Read more on this topic here;
http://www.vaporpark.com/invboard/in...ST&f=12&t=310&
Cheers!
size of CR window cmick Studio Building & Display 7 04-12-2007 02:20
Under-rated Lyricists LimoWreck Songwriting, Singing & Vocals 39 09-13-2004 22:53
Wood, and hardware?(Production desk materials) Voxpopuli Studio Building & Display 10 01-30-2004 21:18
Converting MIDI to WAV AndrewSales Cakewalk / Sonar Forum 38 08-21-2001 22:31
How do you make a balanced 1/4 inch to 1/4 inch cable?? n/t Skyline609 Newbies 0 01-21-2000 15:11
