Go Back   Home Recording > Equipment Forums > Keyboards and Sound Modules
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 12-13-2004
ursaminor ursaminor is offline
Newbie
ursaminor is on a distinguished road
Question exporting my own modified samples 2 roland td 3 drum machine tho midi...
a post earlier said this could be done........but didnt explain wat software 2 use or how 2 use it, the problem is i am not totaly happy with the sounds on the td3 (not exactly made for metal) so i wanna use drum sounds that i have created and modified 2 come out of the drum machine when i hit a certain trigger. for example. hit trigger one on td3 and "poppy snare" from computer is heard, trigger 2 on td3 and "fat bass drum" from computer is heard, when it comes 2 midi and all things invloved i may as well curl up in a ball and shit my pants coz i am pretty much lost with it so if you guys could please explain 2 me how this is done it would be muchly appriciated, also can i export my own modified wave samples or is it only midi sounds, and if i have a wave sound can i transfer it 2 midi some way so i can play the dam thing thro my kit!!!..... thanx!
Old 12-13-2004
Atterion Atterion is offline
The Dark Knight
Atterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond repute
What you're probably thinking of here is using MIDI (which is data only, not sound) sent from the TD-3 to the computer, to trigger samples of drums in a software sampler such as Kontakt. In order for it to work properly, you need to have the TD-3 hooked up via MIDI to the computer, and know which MIDI note data each pad sends when pressed. Then assign your samples to those notes respectively in your Soft-Sampler, and set the hardware MIDI input in the soft-sampler to the MIDI port that the TD-3 is hooked up to (and to the channel it transmits on, which is usaully Channel 10 for drums but can be changed to whatever channel you want, both in the TD-3 and in software). That's it!!!
And remember with this set up, your not just limited to drum sounds. You could assign individual pads to trigger different sounds (i.e. Air-Raid Siren on pad 1, Scream sound on pad 2, etc.).
Torment, Violent Aggression,
Systematic State of Oppression.
The Heretics, All Swing From The trees,
Cast To Hell, With Their Disease. DARKENED
Old 12-13-2004
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
For midi basics, go here and here --- then you'll need sample-playback software to use with your PC. Let's take it one step at a time though.
Use the links above and maybe google 'midi basics' for yourself.
how to use midi sync with drum machine & NI's BATTERY stingray Cakewalk / Sonar Forum 1 10-29-2003 12:03
dr 660 drum machine 4 sale. xpurt Keyboards and Sound Modules 2 09-19-2003 08:00
A program w/ drum samples for MIDI? SpeedKing9 Cakewalk / Sonar Forum 13 11-08-2002 12:31
drum machine with midi Joejoe Newbies 2 05-28-2000 20:59
new studio need help.. fast!! Readytodothis Newbies 8 04-06-2000 01:55
