Old 12-11-2004
loose_unit loose_unit is offline
Newbie
loose_unit is on a distinguished road
Echos off walls
hi, i was wondering what would be the best materials to use on walls and celings that would stop echoing?
it's kind of annoying.
Old 12-11-2004
Buck62 Buck62 is offline
Blah, blah, blah...
Location: Chicano, Illinoyez... a.k.a. "Guadal-o'Hara North"
Buck62 has a reputation beyond reputeBuck62 has a reputation beyond reputeBuck62 has a reputation beyond reputeBuck62 has a reputation beyond reputeBuck62 has a reputation beyond reputeBuck62 has a reputation beyond reputeBuck62 has a reputation beyond reputeBuck62 has a reputation beyond reputeBuck62 has a reputation beyond reputeBuck62 has a reputation beyond reputeBuck62 has a reputation beyond repute
If stopping echo is your only goal (and you want to keep it cheap), then some thick blankets all around will do the trick. If you want proper sound absorption and a "dead" room, then using a decent-quality studio foam like 2-inch Auralex is ideal for that purpose.
Old 12-12-2004
DigitalSmigital's Avatar
DigitalSmigital DigitalSmigital is offline
A slice of analog pie?
DigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond repute
If you are talking about recording in that room, just make a tent around the source and mic with blankets.
If you meant for rehearsal purposes, what he said.
Old 12-12-2004
Rod Gervais Rod Gervais is offline
Force of Nature
Rod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond repute
Unless you plan on applying a fireproofing fabric to the blankets - I would advise you to avoid that approach - blankets hanging down around your walls is one hell of a fire hazzard - and they go up real fast.
The foams are an effective product - as are rigid fiberglass - 703 or 705.
If you hang rigid fiberglass a few inches off the walls (and below the ceiling) it will help with high frequency reflections as well as tame some of the mid and higher bass frequencies.
I would avoid a completely dead room if I were you - it's very annoying.
Be certain that whatever materials you use are properly fire retardant, including whatever cloths you might use to wrap the fiberglass with should you go that route.
Rod
Bass traps, angled walls, floating floors Bulls Hit Studio Building & Display 3 10-22-2003 08:15
Sand filled walls Henrik Studio Building & Display 32 02-05-2003 17:17
Keeping sound from bouncing all over the room with plaster walls for better vocals??? pisces7378 Recording Techniques 17 01-28-2002 08:04
Portable/moveable walls Garak Studio Building & Display 0 12-10-2001 18:03
Bare Walls or Carpet moelar2 Drums and Percussion 2 11-22-2001 23:02
