Old 12-09-2004
HangDawg's Avatar
HangDawg HangDawg is offline
bUnGhOlIo
HangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond repute
Universal Shock Mounts.
Has anyone used one of these? http://www.tensimount.com/ They are cheap enough, I just wonder if they work well. I'd like to get enough to do a drum kit with. I think it would make a big difference if I could get rid of most of the stand noise.
http://www.garagerecording.com/images/lava22.gif
SELECT W.People
FROM tbl_world W
WHERE W.Clue = TRUE
NO RECORDS RETURNED
Old 12-09-2004
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
I'm sure it would work fine. How are you micing the drums to make stand noise an issue?
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 12-09-2004
HangDawg's Avatar
bUnGhOlIo
Isn't stand noise always an issue? If it's not, why then do they always use a shock mount when tracking vocals? There's alot less motion/pounding/vibrations when cutting a vocal track, no? When you have someone pounding on the drums, there will be vibrations transmitted through the stand and into the mic.
SELECT W.People
FROM tbl_world W
WHERE W.Clue = TRUE
NO RECORDS RETURNED
Old 12-09-2004
HangDawg's Avatar
bUnGhOlIo
Well, anyone else? Reasons not to use them? Complete waste of time?
Bueller!
Bueller?
SELECT W.People
FROM tbl_world W
WHERE W.Clue = TRUE
NO RECORDS RETURNED
Old 12-09-2004
Farview's Avatar
Vocals are normally a lot quieter than drums and some sigers tap thier foot on the mic stand base. Drum mics also tend to have internal shock mounting to isolate the capsule from the body of the mic and stand. If you are using mics that were not intended for drums ( AT 4033's for example), the shock mounts might be a good idea. Otherwise, unless you are really having an audible problem (in which case you might need to hit the drums harder), I wouldn't bother.
Jay Walsh
Old 12-09-2004
HangDawg's Avatar
bUnGhOlIo
So you're telling me that sm57/md421 have internal shock mounts? If they don't, then they are not intended for drums?
SELECT W.People
FROM tbl_world W
WHERE W.Clue = TRUE
NO RECORDS RETURNED
Old 12-09-2004
Farview's Avatar
The 421 does, the '57 doesn't suffer from handling noise because of it's design.
Are you actually having a problem with mic stand noise?
Jay Walsh
Old 12-09-2004
HangDawg's Avatar
bUnGhOlIo
Some. If I solo the mounted tom track, I can hear some noise. Tried the same mic with a shockmount (not meant for this mic but it worked for the test) and it made a difference. It's not that there is a huge amount of noise, but any is too much. And I figure with 7 drum mics, that could add up.
SELECT W.People
FROM tbl_world W
WHERE W.Clue = TRUE
NO RECORDS RETURNED
Old 12-09-2004
Farview's Avatar
If you think it is a big deal and worth the extra money, go for it. I have never run into this problem. With all the rumblings and thunder coming off of a drumset, this was always the least of my worries.
Jay Walsh
Old 12-09-2004
HangDawg's Avatar
bUnGhOlIo
I've been getting good results lately but I figured this could be one more step in the process of achieving that elusive great drum track.
SELECT W.People
FROM tbl_world W
WHERE W.Clue = TRUE
NO RECORDS RETURNED
Shock mounts. ecktronic Recording Techniques 7 12-12-2004 11:13
AKG c3000b and shock mounts solarscar Microphones 1 07-09-2004 00:22
Oktava shock mounts H2oskiphil Microphones 5 07-06-2003 21:05
Shock Mounts Markd102 Microphones 3 04-28-2002 00:58
Shock mounts? Garak Microphones 8 01-19-2002 18:13
