Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 04-16-2000
cobweb cobweb is offline
Newbie
cobweb is on a distinguished road
Wink
I incorporated a Mackie 1202 VLZ Mixer into my setup; so you'd think I'd get better recordings....WRONG. I have a Gina soundcard and a keyboard and drummachine. I have the keyboard hooked up to line 7/8 of the mixer, the drummachine is on line 5/6, the line in from the Gina breakout box is connected to the Main out, the line out labelled channels 1 and 2 from Gina are connected to the Tape input on the mixer (RCA plug), the amp is connected to the Control Room.
I had better sound when I recorded into Acid when I just connected the line out from the instruments into the line in on the Gina; without the mixer. I am watching the record levels in Acid and also I set the levels in the Gina mixer.
In the new setup incorporating the mixer the drum sounds sound muffled. The levels on the mixer are all set at Unity; except for the volumes. Like I said I had better recordings (wav files) when I just plugged the instruments into the line in on the Gina and recorded into Acid. Oh yeah I should mention that in the new setup which incorporates the mixer, I am doing something else a little bit different also..... I am now using the drummachine to sequence the drums I loaded into the keyboard (midi) instead of using the keyboards onboard sequencer. From there I record into Acid. I have noticed now for several day taht the sounds of my recordings sound different and are not as clear as before. The sound not only is muffled but sounds lifeless and boring/weak etc. etc. I am monitoring the sounds with Yammy NS 10s. The sequence sounded better on headphones but not the monitors. Help.
[This message has been edited by cobweb (edited 04-15-2000).]
Old 04-16-2000
Newbie
Wink
Yep I saw your other post on the other forum too. Cool, in 3 days when I have the time I will sort thru the archives on this site and find the answer you are insinuating is already here. You are supposed to be a Moderator; instead you are offering nothing. Talking shit....
As far as the "Low tech" comment goes ...kiss my ass.
I told the same thing on the other forum too.
Old 04-16-2000
drstawl's Avatar
drstawl drstawl is online now
5K Californium Member
drstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond reputedrstawl has a reputation beyond repute
Unhappy
So cobweb has discovered that you'll need a much better mixer than that Mackie to match the sound you can get going straight into the GINA <and> get the convenience of the mixer. This is important to the throngs out there who haven't purchased anything and don't want to buy shit they won't need.
This has also been my conclusion from researching what a mixer could do for my setup. But since I don't own one I do appreciate honest testimony from others about such variables in the sound chain to corroborate my findings. So thanks, cobweb.
And there is no need to cross-post.
This is an active community.
Since this post was re:
"the effect of a mixer on your sound chain", this forum seems most appropriate.
