Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 03-24-2000
Rev E Rev E is offline
Force of Nature
Rev E has a reputation beyond reputeRev E has a reputation beyond reputeRev E has a reputation beyond reputeRev E has a reputation beyond reputeRev E has a reputation beyond reputeRev E has a reputation beyond reputeRev E has a reputation beyond reputeRev E has a reputation beyond reputeRev E has a reputation beyond reputeRev E has a reputation beyond reputeRev E has a reputation beyond repute
Lightbulb
TheJester,
I would recommend turning the master to its unity position (it may be marked as "0"). It's usually about 75% of the fader. Then turn up the individual channels as needed.
Rev E
Old 03-24-2000
TheJester TheJester is offline
Newbie
TheJester is on a distinguished road
Wink
When i mix down i was wondering if i turn up the line (individual track volumes) volumes more or the master (all at once)? Im just using a 4 trac fostex?
Old 03-28-2000
The Green Hornet The Green Hornet is offline
Been Here, Posted That
The Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond repute
Cool
Ho Ho Ho JESTER:]
Mic-line usually controls ADDED VOLUME OR TWEAKED VOLUME WHEN YOU ARE INPUTING A SIGNAL, LIKE A SYNTH or vocal or whatever;
when you mix down, your mic/line volume knob won't do ANYTHING FOR YOU. The mixdown volume, for most recorders, is controlled by the MASTER FADER AND THE CHANNEL FADERS, and to some extent, how you tweak the EQ knobs.
So, mic/line input is used to get your signal loud enough to suit you or to add just a little more volume to the incoming signal.
Green Hornet
Watch out for Henry the 8th
Old 04-03-2000
Newbie
Wink
thanks that explained it good
