Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 03-29-2000
Rusty K's Avatar
Rusty K Rusty K is offline
1K Silver Member
Rusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond reputeRusty K has a reputation beyond repute
Wink
Would someone explain "notch" EQ settings and their application for me?
Thanks much.
Rusty K
Old 03-29-2000
Shailat's Avatar
Shailat Shailat is offline
Period
Shailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud of
Wink
A Notch filter is for finding a problematic Freq. like a hum
or noise from a fan etc...
Notch filters have a very narrow bandwidth, they are usually sweepable and in many cases cut only.
Old 03-29-2000
Rusty K's Avatar
1K Silver Member
Wink
I had also asked earlier about eleminating string noise from a recording. Would it work in that application? Just move the "notch" to the narrow range of problem frequencies?
Thanks Shailat,
Rusty K
Old 03-30-2000
Shailat's Avatar
Period
Wink
It should work also.
Just search for the specific Freq., (using a parametric EQ) that is the problem by Boosting the bands, and then search through untill you hit it ( you'll hear the problem stand out ).
Then go to your notch and cut that specific freq.
Another usefull trick is to use a De esser. Do you have one?
[This message has been edited by Shailat (edited 03-30-2000).]
