TEAC 3340 output noise
My 3340 has developed a SHHHH(like steady wind) noise on track 3 when in Tape Mode. The output level affects the noise. It seems worse in Simul-Sync Mode. Any ideas?
simple solutions first.
Are you using the deck with noise reduction? If so, is the channel bypassed for it on track 3?
Is this a multiple occurrence? No matter what you try to record, all you get is hiss and no signal? Or, is there hiss and the signal, only higher now then before? Sorry for all the question. Cheers! ![]() |
Teac Noise
I have hiss and signal. If I turn down the output of #3 when mixing I can "live with it". However for low level stuff it's maddening.
TEAC noise
Oh yeah, I forgot. I don't use noise reduction.
That is where the term "re-capping" comes from should you ever encounter it when talking about vintage electronic equipment. |
Is this an easy fix? About how much would it cost? I really like using this deck for my songwriting stuff and can't really afford to upgrade right now. I do a lot of my own maintainace and would be willing to try to do it myself if I knew what to do. Am I dreaming?
The sound a faulty cap usually makes is a "swooshing" sound like a jet plane. Some other sounds are funny feedback like " woop, woop" sounds and "thumping" sounds. A constant "hiss" might not be a cap problem. Before I would bother looking for this type of problem, however, I would align the deck and bias it to see if the problem goes away. The giveaway here is that it only happens on ch3. So, the power supply and any other electronics common to all channels is probably ruled out. |
Thanks for all your help Acorec. As none of my recorded stuff is for release I'm going to live with the hiss for now. All I do is work on songs that I have written and maybe play them to my teenage kids. With chritmas coming I have a lot on my plate but I might attack it in the new year. If I do I'm sure I'll post again for guidance. I AM going to do the alignment and bias as soon as I can get my hands on a test tape and maybe a scope. Thanks again and happy ho ho.
| All the World's Tube Microphones PART ONE | Bambi Busboom | Microphones | 2 | 08-15-2004 04:02 |
| Fostex 3040 Dolby C Noise Reduction units w/ TEAC 80-8 adapter cable | davidio7 | Fostex Forum | 1 | 07-20-2004 10:07 |
| TEAC 80-8 Dolby C Noise Reduction w/ Fostex 3040 units | davidio7 | TASCAM User Forum | 0 | 07-19-2004 12:15 |
| Lowering Backround Noise!!!! | Raydio | Recording Techniques | 13 | 03-01-2003 04:28 |
| hummm - if i hear this noise again i will scream | one | Newbies | 7 | 05-19-2000 02:38 |
