Old 11-25-2004
mrmope's Avatar
mrmope mrmope is offline
Newbie
mrmope is on a distinguished road
VF-160 External pre's
I think this may have been dealt with before, but I just can't seem to get it right. How do you hook up an external mic pre so that it overides the pre's in the VF-160. And after it is hooked up, what is the procedure to record?
Thanks
Old 11-26-2004
billisa billisa is offline
1K Silver Member
billisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond repute
I believe the only way to actually over-ride the interal pre is to go in via the inserts on channels 7/8.
Otherwise, go from the external outs through the 1/4" or XLR and turn the VF160 gain all the way down. Use the external input/output gains to adjust levels on the VF160.
Old 11-26-2004
carelessorc carelessorc is offline
Dedicated Member
carelessorc has a reputation beyond reputecarelessorc has a reputation beyond reputecarelessorc has a reputation beyond reputecarelessorc has a reputation beyond reputecarelessorc has a reputation beyond reputecarelessorc has a reputation beyond reputecarelessorc has a reputation beyond reputecarelessorc has a reputation beyond reputecarelessorc has a reputation beyond reputecarelessorc has a reputation beyond reputecarelessorc has a reputation beyond repute
I think Bill's right about the inserts: connect the outputs of your external pre to the 'ring' connector of a stereo jack, and plug it in to the insert. Or you could use a mono jack and only push it in part-way, but this is not so good I think.
Of course if the pre has a digital output you can connect that straight into the optical input on the Fostex.
Mike
Old 11-30-2004
timboZ's Avatar
timboZ timboZ is offline
Band-Aid®
timboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond repute
Use the insert jack and push it in to the first click.
