Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 11-23-2004
SittinIdol SittinIdol is offline
Senior Member
SittinIdol has a reputation beyond reputeSittinIdol has a reputation beyond reputeSittinIdol has a reputation beyond reputeSittinIdol has a reputation beyond reputeSittinIdol has a reputation beyond reputeSittinIdol has a reputation beyond reputeSittinIdol has a reputation beyond reputeSittinIdol has a reputation beyond reputeSittinIdol has a reputation beyond reputeSittinIdol has a reputation beyond reputeSittinIdol has a reputation beyond repute
Need some opinions on this mastering job please
Hey guys, I wrote about this in the mixing clinic as well but it's not really a mixing issue so I thought I'd get some opinions from the mastering gurus...
I've posted a few songs, mastered and unmastered versions here:
http://www.soundclick.com/bands/9/sittinidolmusic.htm
I don't know if I'm being anal, but I think I'm hearing some slight compression artifacts mostly in the kick drum on the mastered versions? I might ask the mastering engineer to drop the volume a few db and get back some of the dynamic range.
I guess it's inevitable when boosting up a song to commercial volume to compress the peaks. Let me know what you guys think of the two versions please?
Thanks
Rick
Sittin' Idol
http://www.sittinidol.com
Old 11-23-2004
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Well - your mastering engineer did a good job of adding punch and livening-up a mediocre and somewhat lifeless mixes, so I wouldn't worry about it too much. The mastered versions sound quite a bit better than the unmastered versions, IMO.
Old 11-23-2004
Senior Member
Cool
Thanks I guess...which songs did you listen to by the way?
Sittin' Idol
Old 11-23-2004
First couple...
Old 11-23-2004
Marciano Marciano is offline
Newbie
Marciano will become famous soon enoughMarciano will become famous soon enough
i think the main problem on this master isn't the master at all...the problem is with the mix. It has no Bottom... Try giving something more bottom to your kick drum. This prés sound mackies,isn´t it??
To mutch high end on the guitars...sounded like metallica in the 90´s.
Give more clarity to your voice track...sounds to closed...remove somthing arround 500, 600 hz on your voice track. To mutch botton mic on the snare. Try another compressor on the snare and a diferent reverb on vocals and snare, that one is just to bad...
You mix on Daw ou analog?
Put your mix material here...´
Marcio Silva
Old 11-23-2004
Newbie
And the master isn't to loude at all...haved heard things alot louder.The thing that i´m missing is warmth. This mastering was made on analog ou digital?
Old 11-24-2004
Senior Member
Thanks for the reply Marciano, just for reference which song are you referring to?
The pre-amps are not Mackies, they are Allen + Heath System 8. I'm mixing digitally with n-track.
Please give a listen to the other tracks, they are all completely different from each other.
Is metal supposed to sound warm?
Thanks again
edit: Just added "Homestead" and "Stray", curious what you think of those?
Sittin' Idol
Old 11-25-2004
ChristopherM's Avatar
ChristopherM ChristopherM is offline
Force of Nature
ChristopherM is on a distinguished road
Thumbs up I'm not a mastering engineer but...
I'd be very happy with the job done on these mixes.
Your mastering engineer did a good job of livening up the mixes.
I listened to all the songs, by the way.
www.ChristopherMast.com
Old 11-26-2004
masteringhouse's Avatar
masteringhouse masteringhouse is offline
www.masteringhouse.com
masteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond repute
Weird coincidence, I went to your link and found the banner page pointing to one of my recent mastering projects.
"The Great Escape" Live Not on Evil
http://www.soundclick.com/bands/1/livenotonevil.htm
Very cool tune and band, though the MP3 doesn't do justice to the mastering job!
Oh yeah, and the mastering done on your project is very good.
Tom Volpicelli
The Mastering House Inc.
MySpace:
www.myspace.com/masteringhouse
Old 11-26-2004
kylen kylen is offline
Force of Nature
kylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond repute
Rick
Go for it - the ME can surely drop the loudness a few dB for you if you ask.
I listened to both versions of the first cut named Homestead, I adjusted the rms and crest of the unmastered version to about the same settings the mastered version has using a DAW VST limiter and both versions sound pretty similiar that way. Sometimes bass stuff looses some of it's definition when it's adjusted loud like that - at least some of my commercial releases have that sound - compression artifacts I guess you're calling it.
Good job on the mix and by the ME - it's done!
Old 11-28-2004
Senior Member
Thanks guys, I'll keep you posted on how it turns out
Sittin' Idol
  #12
Old 11-29-2004
foreverdown foreverdown is offline
Senior Member
foreverdown is on a distinguished road
the mastered version sounds heaps better than the unmastered. I think they did a great job. One thing that doesn't really pertain to the master job, but I don't think you guys are very metal. That's just my opinion though.
http://purevolume.com/foreverdown <-- my music
