Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 11-22-2004
bairradino bairradino is offline
Newbie
bairradino is on a distinguished road
16 bit -> 32bit -> 16bit
Is there any advantage in transforming 16 bit recorded material to 32 bit, for mixing and mastering, and then re-transform again to 16 bit for recording?
Old 11-22-2004
ecktronic's Avatar
ecktronic ecktronic is offline
Mr Mix and Master Man.
ecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond repute
I would say there might be an advantage be it a small one. The already recorded tracks will not magically be of a better quality by changing the resolution to 32 bit. But i think if you master it in 32 bit the effects you add might possibly make the overall sound a bit better than if mastering at 16bit. At the same time though you will use up maybe 2-3 times the amount of storage by converting up. Why not record in 32 bit 91kHz. Then you will get a better sound but your hard drive will hate you for it.
Million dollar ears.
CRYSTAL MIXING
MY BAND
Old 11-22-2004
Clit Torres's Avatar
Clit Torres Clit Torres is offline
Dedicated Member
Clit Torres is infamous around these partsClit Torres is infamous around these partsClit Torres is infamous around these partsClit Torres is infamous around these partsClit Torres is infamous around these partsClit Torres is infamous around these partsClit Torres is infamous around these partsClit Torres is infamous around these partsClit Torres is infamous around these partsClit Torres is infamous around these partsClit Torres is infamous around these parts
IMHO, there's no real advantage to upsampling to 32bit unless you're gonna be doing any offline processing during mixing/mastering.
Old 11-22-2004
Bulls Hit Bulls Hit is offline
Been Here, Posted That
Bulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond repute
There may be an advantage in that the cumulative effect of rounding errors as a result of digital operations & calculations will be smaller in a 32 bit number than a 16 bit number.
However the s/w may translate to 32 bit for internal calculations anyway, in which case there's no advantage
Old 11-23-2004
crankz1's Avatar
crankz1 crankz1 is offline
crankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond repute
Yeah, most programs do their internal DSP at 32 bit float now days anyway.
Best thing to do would be to upgrade to a 24 bit card with quality converters, allowing for a greater dynamic range.
~It all works out in the end~
Old 11-23-2004
Newbie
Thanks guys.
The material was recorded, two years ago, with a 16 bit sound card.
According your comments I'll convert the tracks to 32 bit before applying denoisers, Eq's and compressors.
