Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 11-20-2004
thewifey's Avatar
thewifey thewifey is offline
Newbie
thewifey is on a distinguished road
Question EQing "finger snapping"
Where in the world do I start with EQing "finger snapping"? It's a Christmas song with a Blue's feel. Everything else sounds fine, just not sure where to begin with this rhythm piece.
thewifey
www.deannak.com
"music touches the heart when words can not"
Old 11-20-2004
Cloneboy Studio Cloneboy Studio is offline
Cloneboy Studio will become famous soon enough
I'd suggest a fairly bright SD condensor like a C451 or SM81 about 18" from the source. I'd record a number of them until I had maybe 4 or 5 I liked and then I'd save the good ones to individual audio files to use as samples.
Once you have them individually snip and cut the waveform just right, apply some compression and normalization to optimize the sample and them trigger them via MIDI, or insert them 'by hand' in a DAW.
Old 11-20-2004
thewifey's Avatar
Newbie
I did record using a Behringer B1, about 14-inches from the mic with pop filter in place. This runs through a Digitech Studio vocalist; running through the pre-amp no effects applied. I recorded a good set, just want to brighten it up slightly (it's a little muddy for my liking)...where is the best place to add/cut on the EQ?
thewifey
www.deannak.com
Old 11-20-2004
Mr Nice's Avatar
Mr Nice Mr Nice is offline
Senior Member
Mr Nice is on a distinguished road
If what you recorded is muddy, you may want to roll off the lows a bit and maybe raise the highs to add that airy sound to it. I cant tell you exactly what frequency to roll off or add, because I dont know how the "fingersnap" sounds in the first place. My advice would be to experiment with the EQ and see where it takes you. Hope this helps.
Check Out The Links!
Old 11-20-2004
thewifey's Avatar
Newbie
Thanks I'll give this a try in the morning (with fresh ears)!
thewifey
www.deannak.com
Old 11-20-2004
Mr Nice's Avatar
Senior Member
Your welcome dude!
Old 11-21-2004
thewifey's Avatar
Newbie
Thanks, that worked!
thewifey - dudette
thewifey
www.deannak.com
Old 11-21-2004
Mr Nice's Avatar
Senior Member
Dudette??? Ooops I am so used to male engineers. LOL
Glad I could help you out!
Old 11-21-2004
thewifey's Avatar
Newbie
Yeah, I know there aren't too many female engineers <chuckle>
thewifey
www.deannak.com
Old 11-21-2004
Mr Nice's Avatar
Senior Member
I think that is very sexy!
Old 11-21-2004
thewifey's Avatar
Newbie
Wink
Sexy??? Mmmmmm......I didn't start out to be an engineer...sort of "fell into it". Like everyone else, I wanted to be able to work with my own music, on my own time.
thewifey
www.deannak.com
  #12
Old 11-21-2004
Mr Nice's Avatar
Senior Member
I wanted to buy my own studio stuff so I can work on my own material at my own pace also.
  #13
Old 11-21-2004
thewifey's Avatar
Newbie
Like most I suffer from G.A.S. gear aquisition syndrome...there's always something more I want. How 'bout you? I like the look and feel to your site BTW. Mine needs (and is in process) of an overhaul.
thewifey
www.deannak.com
  #14
Old 11-21-2004
Mr Nice's Avatar
Senior Member
Like most I suffer from G.A.S. gear aquisition syndrome...there's always something more I want. How 'bout you? I like the look and feel to your site BTW. Mine needs (and is in process) if an overhaul.
Hahahaah @ GAS (Gear Aquisition Syndrome). I had that bug but I had to draw the line somewhere! I still would like to get a few more things, but I am OK for now. Thank you for looking at the pics (there are 2 studios) Panic Room is my friend Mikes and The Pentagon is mine, (I built both of them) Here is the link! Those are old photos of the desk, I have my computer in a rackmount case now here
My PC is in a desperate need of an overhaul too. I am still running a P4 1.3Ghz w/256MB RAM. I seen your site too, I like the set-up you have also, it looks warm and comfortable to be in. I was reading your gearlist. You have more stuff than I do
I see you have 2 soundcards, I hope your using the Echo MIA for recording? I have the Gina/24. Echo makes good sound cards.
What version of Cubase do you have? I use SX
  #15
Old 11-21-2004
thewifey's Avatar
Newbie
The photos in my studio are about 1-year old and need to be updated. I have a couple newer pieces. Just replaced my dbx compressor with a Behringer T1952 Tube and would like to pick up the T1953 Mic Tube Preamp. I also just replaced my small Yamaha (which I used for writing and transporting) with a larger one. It is a nice warm inviting space...I get lots done in there.
I just upgraded the video card in my PC with a 64MG NVIDEA, made a huge difference in performance. Even though the PC is a 933Mghz, I'm not looking to upgrade the processor for a while. With 512RAM, the faster video card and two hard drives at 7200 RPM's it runs fast enough. I stripped off all email, internet and web design software off of it so it's just dedicated to music, CD burning and CD cover design. I have a 2.6 Ghz wireless laptop for everything else. Everything gets initially recorded into a Roland VS-840EX, no compression or anything. Then it gets sent into the PC, through the mixer, compressor and BBE maximizer via the Echo Mia for final mastering. I have the Echo also routed into my mixer for playback. The other sound card is for everything else, but it's also nice to use it for "test" listening. I test listen on the PC and also on a small boom box that's in the studio.
I have Cuebase SX but still have yet to truly master it. I'm using Adobe Audition 1.5 to record and do some initial clean-up. Then it's into WaveLab 4.0 for the final mastering. I do want to get into using Cuebase more, but don't find it as user friendly.
I picked up a big chunk of my gear from my "mentor" who is a comercial studio owner in the area.
thewifey
www.deannak.com
  #16
Old 11-22-2004
Mr Nice's Avatar
Senior Member
It sounds you have a certain system that works for you (thats a good thing). I track and mix everything into cubase SX. I have a mackie 24x8 bus that all my external gear is patched into including the computer. I create everything in MIDI format within SX and then I record each MIDI track as an audio track onto a dedicated audio drive (Ultra160 SCSI). For me to record an audio track I would simply route the channel strip into my computers sound card. The Mackie board has a flexible switching design called (Mix B), and I can route any single or combo of channels to the Mix B output, which is patched into my Echo Gina inputs.
I had a Geforce4 64MB card, I liked the nVidia chipset but I upgraded to an ATI Radeon 128MB 9200se W/TV and DVI output so I can use dual displays. I love the twin monitor set-up. It enables you to work more effeciently, I can have my project window on one screen whille my mixer and other things can sit on the other screen. There is less hassle than one screen where you would have to shrink things to view something else. Once I switched to dual view, I dont know how I dealt with only 1 screen.
I still want some more synths, but I am not sure about getting hardware because now I been using more of the VST instruments. If my drive continues to use VST instruments I will need to upgrade my CPU and RAM soon.
  #17
Old 11-22-2004
Teacher's Avatar
Teacher Teacher is offline
do unto others......
Teacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond repute
lol@ home rec becoming the dating game
looks like Mr. Nice is nice with the words
"...if the opposite of pro is a con lets go beyond this, the opposite of CONgress must be PROgress..." Cage
  #18
Old 11-22-2004
ecktronic's Avatar
ecktronic ecktronic is offline
Mr Mix and Master Man.
ecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond repute
Well a twig snap is around 2kHz which i beleive is our optimim hearing frequency. So i woud think that a twig snapping and fingers clicking would be of similar frequency, so too get a brighter sound maybe boost at around 2kHz or so. Just a guess.
Million dollar ears.
CRYSTAL MIXING
MY BAND
  #19
Old 11-22-2004
Mr Nice's Avatar
Senior Member
Awe man, nah! me and thewifey are just having a friendly chat about studio gear thats all. As you can see by her user name she is already spoken for. I seen her picture on her site and if she doesnt mind me saying she is very attractive looking!
lol@ home rec becoming the dating game.
  #20
Old 11-22-2004
thewifey's Avatar
Newbie
Wink
No, I certainly don't mind compliments - bring 'em on. Now to make you REALLY laugh - guess my age w/o looking at my profile!
The only time I do anything with MIDI is if I want to write a score for a musical piece. Then I use the Audigy breakout box and send into CakeWalk Scorewriter, though I just picked up Finale 2005 to replace it. One of the musicians/sound engineers I work with in the area uses lots of MIDI so from time to time, I'll work with his. Mackie makes some NICE equipment! I've not thought of the dual monitor route, most likely due to a space issue. It would be nice to have a larger viewing area when I'm mastering within WaveLab, as I have to move plugins around to get a clear view.
Which VST instruments are you using?? I've been pulling mine off my keyboards (and some live), would like to have other options expecially with some orchestral types.
thewifey
www.deannak.com
  #21
Old 11-22-2004
Mr Nice's Avatar
Senior Member
After seeing your picture I would have to say late 20's early 30's. You look around my age bracket. I assume you are older or you wouldnt be asking this question. If you are much older than I specified then you look very young for your age.
Once you go 2 screens you will never go back to using 1 again. I have my screens plopped right up between the studio monitors. There is a wide enouph space to fit 2 - 19" screens.
I use the VST's that come with cubase, like monologue, a1, but mostly from HALion (sampler). I find myself using more of the halion to complete drum beats and also to add some melodies too. I just finished a whole R & B type track with a singer using HALion for about 90% of the track.
  #22
Old 11-22-2004
Mr Nice's Avatar
Senior Member
I just looked at your profile, you dont reveal the year you were born. So I couldnt of cheated and peeked at it.
  #23
Old 11-22-2004
thewifey's Avatar
Newbie
I will be 42 in January! I'm even a grandmother LOL
Before I could go with dual screens I would have to revamp the entire set up. For now I'll continue using 1024x768, which though the view is small...it works. Which version of HALion are you using? Now my next ques would be "Does WaveLab support VSTs?". Think I'll check that out.
thewifey
www.deannak.com
  #24
Old 11-22-2004
kragbax kragbax is offline
Senior Member
kragbax is on a distinguished road
Wow! You've got one amazingly lucky husband!
Course, I'm lucky as well - my wife recently hit 40 and is still consistently thought to be in her 20's. So I'm lucky - and yes I know it Except my wife isn't in to the recording thing, though my constant purchases leave her with gas - and I'm not talking about gear acquisition! That's probably a good thing however because otherwise we'd be (more) broke if we both were buying gear!
Best of luck in your musical endeavors!
-Krag
  #25
Old 11-22-2004
Mr Nice's Avatar
Senior Member
42!! God Bless!! You look younger than that. If you did want to go the 2 screens you would probably need to change your video card, (unless it has dual outs already). I have my resolution at 1200x1024 (something like that). I use version 2.2 of HALion. I think wavelab supports VST's because you can use VST plug-ins for it. I use Samplitude 7 Pro for mastering, and it has VST support, but I dont use it to track or mix, I only use it as a mastering/editing tool. The plug-ins that it comes with are pretty powerful as is. I hear wavelab is better though.
