Old 11-20-2004
Myriad_Rocker's Avatar
Myriad_Rocker Myriad_Rocker is offline
Registered Text Offender
Myriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond repute
Track processing is KILLING my CPU
And causing dropout errors immediately.
I'm processing some drum tracks with Drumagog. I guess with it attached to every drum, it's really killing my CPU. What should I do? Is there a way for it to use less CPU? Should I just replace the hits and not even bother with trying to do it on the fly?
Any help is very appreciated. I can't believe this is happening...my comp is fairly powerful.
Intel P4 3.0Ghz
2Gigs of RAM
800Mhz FSB
Myriad Rocker
My Web Design/Production Company: Myriad Productions
My Band: Black Leaf Clover
Originally Posted by theblackBay View Post
I’m currently "one" of the best song writers in the world
Old 11-20-2004
manning1 manning1 is offline
Banned
Location: Canada.PLEASE NOTE>>I DONT WORK FOR NOR HAVE I EVER WORKED FOR ANY COMPANY WHOSE PRODUCTS I LIKE AND RECOMMEND.
manning1 is on a distinguished road
if you are getting droputs that quickly it could be a number of reasons.
you have plenty of ram and a powerfull processor.
tell me a little about your hard drives. how many for starters ?
Old 11-20-2004
crankz1's Avatar
crankz1 crankz1 is offline
crankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond repute
Yeah .... Drumagog is somewhat of a CPU hog, so running several instances of it in real time is going to tax the system quite a bit.
Best bet is to find the replacement sound you want to use and go ahead and process that track offline.
Make sure to save a copy of the original, in the event that you decide to make any changes later on.
~It all works out in the end~
Old 11-20-2004
AGCurry AGCurry is offline
Force of Nature
AGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond repute
That's what the aux buses are for. You can route several tracks to an aux bus and put your effects on that, rather than applying them to individual tracks.
Old 11-20-2004
crankz1's Avatar
True, but that won't really apply with separate replacement sounds for multiple drum tracks.
Each track would end up triggering the same sound.
Old 11-20-2004
Mr Nice's Avatar
Mr Nice Mr Nice is offline
Senior Member
Mr Nice is on a distinguished road
Intel P4 3.0Ghz
2Gigs of RAM
800Mhz FSB
You seem to have a powerful machine right now! What are your buffers set at? Having them below 1024 can start to tax the CPU when using a bunch of effects, tracks VST's etc. Try putting them at 1024 or slightly higher if its lower than that now. Just to let you know when you raise the buffers your latency will rise also.
Check Out The Links!
Old 11-21-2004
Thanks for the suggestions everyone.
I went ahead and processed the tracks with the sounds I wanted to replace with and my CPU load dropped to about 10%. It was riding at about 98%, Warning, and then dropping.
Drumagog is one heck of a CPU hog for sure!
Thanks again.
Oh, and my hard drives...I only have one. It's 7200rpm and 200 or 250 gigs. Don't remember which. I know I should have a dedicated audio hard drive but I don't have the money right now. After I get done with this recording project, I think I'm going to get an 80gig audio recording only hard drive.
Myriad Rocker
Old 11-21-2004
Mr Nice's Avatar
Senior Member
Using a 7200RPM drive can be affecting performance too, especially the more tracks you try to play back. Definitely get a dedicated audio drive!! I use a SCSI ultra160 disc works great and never bogs down even under heavy loads.
Your MoBo seems new enough to support SATA, so you can even use a Western Digital 10,000RPM Raptor SATA drive. You can pick up a 74GB Raptor for about $100 (USD). That should do the trick also.
Good Luck!
Old 11-22-2004
James Argo's Avatar
James Argo James Argo is offline
Fancy Rock N' Roll
James Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond repute
Lightbulb
And don't forget to put dual HD on separate IDE channels (that means you need two cables). And make sure you use new IDE cable (80/strip) instead the old one (40/strip). Just my $0.2...
Jaymz
Keep Rockin' and Rollin'...
Old 11-22-2004
Teacher's Avatar
Teacher Teacher is offline
do unto others......
Teacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond repute
Can't you just bounce the drumagog vsti down to disk? I know everyother vsti/dxi can
"...if the opposite of pro is a con lets go beyond this, the opposite of CONgress must be PROgress..." Cage
