order of FX
Hi - When I use the aux bus for FX - delay in aux 1 & verb in 2, I'm not sure if I'm getting the delay first in the output, as I could if I used them as an insert. (I'm just using GT Pro). And is that the preferred order, so that I can have a little "predelay" since that is not one of the reverb parameters I can set? Thanks...please enlighten me.
Paresh |
I don't know if GT pro will limit one effect per aux, but if you want delay first, then reverb (that's it, serial), then you must insert Delay before Reverb in one aux.
Delay on aux 1 and Reverb on aux 2 is different thing. It's kinda like you route different output of the track to different effect, so it's parallel, not serial. Generaly, effect order is Comp/Gate --> EQ --> Modulation (like chorus, flanger, etc) --> Delay --> Reverb (hall, room, etc). It's not mandatory, it's just the way it's usualy set. EQ is something you can insert anywhere between if necessary. ![]() Jaymz
Keep Rockin' and Rollin'...
