Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 11-17-2004
Ignition. Ignition. is offline
Newbie
Ignition. is on a distinguished road
Same Sound On Different CD Players
Hey Yall,
When I record and then burn to CD, I find the CD sounds different on different systems...I know even pro CD's sound slightly different, but this is extreeme. How can I get more or less the same sound from different systems? Are there Main EQ levels/Frequencies that must be acheived? More Compression? What??? Thanks for any help you can give, and no, I don't have the capability to post a sound clip, sorry.
Old 11-17-2004
Atterion Atterion is offline
The Dark Knight
Atterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond repute
Different systems use all various combinations of speakers, amps and EQs, so different frequencies are emphasized by each. The best thing to do if your having difficulty pinning down the problem, is to check firstly that your monitoring system is up to par (Quality Monitors, placement, room treatment, etc.).
Listen to some favorite recordings on all your systems (Including your monitoring system) side by side with your recordings, and A/B them and write down what sounds out of place to you (Snare louder on system A, too much bass on system B). Then open your files up in your favorite app, and run a frequency analysis or real time analyzer (hopefully you have at least one form of analysis to work with). Compare your notes to what you see onscreen. I tend to shoot for a mix that has a good balance of frequencies across a real time EQ anaylizer (Right in the middle all the way across, but not nescessarilly all frequencies at the same time, that really depends on what the music is doing). you will need to adjust levels and EQs in your mix to achieve this. By the time you get that acclompished, you will also have a more precise picture of what problems you may be experiencing in your monitoring system (I can't stress good monitoring enough!!!). I.E. you may find you have recurring problems with Bass response, which will indicate you need to check your monitor placement, and you may need some form of bass trap.
I personally go even all the way across the EQ spectrum, then adjust the levels into balance from there. Remember that a lot of people use the typical Smile shaped setting on their graphic EQ's when playing back audio on home audio settings. But many home systems may only have 2 bands (Bass and Treble) and those systems are designed (theoretically) to sound good with a flat EQ response, or they might not even allow EQ adjustment (Such as on small portable 2 speaker Tape/CD units...BoomBox style).
Hope this helps. I would definitely look around the web for some ideas with room treatment, Sites like those who actually make the treatments often are a goldmine of information.
Like:
http://www.auralex.com/
http://www.primacoustic.com
Torment, Violent Aggression,
Systematic State of Oppression.
The Heretics, All Swing From The trees,
Cast To Hell, With Their Disease. DARKENED
Old 11-17-2004
Newbie
Thanks Atterion,
I'll try everything you said...I use Alesis "m1 active mk2" for the monitors. They may not be the best, but I'm hoping that they are not the source of the problem. I'll learn more about room treatment as well, I thought I had that covered...but I will check out the sites you recomend.
Thanks again, will probably take a bit for me to check everything and get down to the source, and actually make changes etc, so...in the mean time, if I forget about this thread...thanks, and if I don't write back, it means you solved the greatest part of my problem.
- Brett
Old 11-18-2004
Be Loveless's Avatar
Be Loveless Be Loveless is offline
Dedicated Member
Be Loveless has much to be proud ofBe Loveless has much to be proud ofBe Loveless has much to be proud ofBe Loveless has much to be proud ofBe Loveless has much to be proud ofBe Loveless has much to be proud ofBe Loveless has much to be proud ofBe Loveless has much to be proud ofBe Loveless has much to be proud ofBe Loveless has much to be proud of
My order of tests are
1. Home stereo
2. Shitty Boom Box
3. The Car (possibly the most important or helpful to me)
4. My friend kevins big ass system inside a wharehouse loft.
I find that there is always at least a minor ( usually a major ) adjustment to make after I go through the rounds. Also make sure that you check your mix in Mono and at different levels FREQUENTLY.
The BLUE HUMOURS
