Old 11-17-2004
Mark V Mark V is offline
Newbie
Mark V will become famous soon enough
How do you plug an external mic preamp . . .
. . . into a VF08? It appears that through the XLR mic inputs is the only way, but then I'm going to be passing through the crappy internal preamp which doesn't seem like the optimal arrangement.
Mark
Old 11-17-2004
MadAudio's Avatar
MadAudio MadAudio is offline
Damned if I do
MadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond repute
Go into the line in. You'll need an XLR-to-1/4" cable.
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music.
"Do yourself a favour just shut up, read up then put up." --muttley600
Old 11-17-2004
Newbie
Mad, the only lines in are either the XLR mic inputs or the unbalanced 1/4" jacks. The Preamp has TRS 1/4" outputs.
Mark
Old 11-17-2004
MadAudio's Avatar
Damned if I do
Oh, I was thinking your pre had an XLR out. But you can still use the line input on the VF08. Use a balanced line cable.
Old 11-17-2004
Newbie
So what you're saying is to plug out from the preamp into the mic XLR balanced line in? How should I set the trim? Won't I pick up a lot of noise going through the Fostex preamp?
Thanks,
Mark
Old 11-17-2004
MadAudio's Avatar
Damned if I do
Use a TRS to TRS. Set the trim all the way down at first and try to use the pre to set the level. Then bring the trim up as needed. As for noise, I guess you'll just have to try it and see. It's not like you have any other input options.
