Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 11-16-2004
chills's Avatar
chills chills is offline
Newbie
chills is on a distinguished road
Need help with compression(only experienced mixers and engineers please)
ok im trying to get a better understanding of how to use compression. Lets say that i have a treshold of -9 and i plan to add compression to values above negative -9 with a 2 to 1 ratio.. what would be the end result of my audio signals above -9
im thinking that with a 2 to 1 ratio i would have a gain of 4.5 above -9 what does that do to my signals above -9
Old 11-16-2004
xstatic xstatic is offline
Been Here, Posted That
xstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond repute
I believe that it reduces all signal over your threshold by the fraction. So at 2:1 with a threshold of -9, if you give it signal at -3, it would only pass 1/2 of whatever the overshoot is resulting in an output of -6. change the ratio of the same input signal to 3:1, the output level will be -7, change it to 6:1, output -8. Basically, the lhigher the ratio, the less the output, or the more it compresses.
Old 11-16-2004
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
Yeah, it's basically as simple as the math. The threshold dictates where compression starts, the ratio dictates how much. This assumes there isn't a soft-knee or other "knee-type" adjustment, which would tend to "soften" the point where compression starts.
But yes - If you're at -10 @ 2:1 and you feed a -10 signal, it comes out at -10. Feed it a -0 signal and you get -5. Every 2dB increase yields 1dB at the output.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 11-17-2004
chills's Avatar
Newbie
thanks alot, i might have some more questions later concerning this
Old 11-17-2004
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Of course, you could also forget the math and just use your ears......!
Old 11-17-2004
ryanlikestorock ryanlikestorock is offline
Force of Nature
ryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to behold
We all know if this guy posted about just using his ears, everyone would post about how it's important to know the math behind it.
Old 11-17-2004
If he had used his ears, he wouldn't have needed to post!
Old 11-17-2004
chessrock's Avatar
chessrock chessrock is offline
Banned
chessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond repute
I don't about know, but my ears are pretty shitty with math.
Old 11-17-2004
That's why you're YOU!
Old 11-17-2004
Force of Nature
Wink
And why did you feel the need to post, exactly?
Old 11-17-2004
Thumbs up
To point out that it ISN'T about math, it's about SOUND... et tu?
  #12
Old 11-17-2004
chessrock's Avatar
Banned
Sounds good to me. Glad we got that one settled.
  #13
Old 11-17-2004
robin watson robin watson is offline
Force of Nature
robin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond repute
There's a new compressor out - it's called the No BrainerComp- which doesn't have any screenprinting on the front panel and no instruction manual. Perfect for beginners and pros alike.
Didn't have a smiley with the expression I had in mind.
  #14
Old 11-18-2004
Oh lighten-the-fuck up, it's called "light-hearted banter" (see you learned something new today!)..............
  #15
Old 11-18-2004
Mosfet Mosfet is offline
Banned
Mosfet is an unknown quantity at this point
That sounds just like the LA2A!
  #16
Old 11-18-2004
Force of Nature
Mine was just light-hearted banter, too, dude - right on the same level as yours. Funny, I never tagged you as a hypocrite, until that post. You're right, I did learn something today...
