Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 11-12-2004
sarias sarias is offline
Newbie
sarias is on a distinguished road
Cymbal eq/compression question
Does anyone have any tips for using eq and compression to bring out the attack (stick) of the ride cymbal in the mix? The overheads in this case were a spaced pair. Thanks!
Old 11-12-2004
GABritton GABritton is offline
Senior Member
GABritton is on a distinguished road
for EQ try pulling a little hi-mid out, around 1-2.5khz just a little. I've had some minor success using an expander for overheads, seems to bring some depth. IMO
Old 11-13-2004
Newbie
Smile
Thanks, GABritton! That worked pretty well. I wound up using a compander and it helped, along with the mid-cut and a little boost around 850hZ. Of course, it will all change when all the instruments have been recorded (so far it's just drums, bass and scratch vocal) but at least I have a bit of a clue now. I'll keep messing with it and if I stumble on to something brilliant I'll post it here. Thanks again.
Rick
Old 11-15-2004
Steal Sessions Steal Sessions is offline
Junior Member
Steal Sessions is on a distinguished road
Well, prepare for a re-do as soon as all instruments are recorded.. did the same thing, 3 weeks between recording drums and after that we recorded 90% of the rest (bass, guitar, vox (lead)). The sound I'd set for the drummix before was dropped within 10 seconds of listening with all instruments in Sonar.. It will make a big difference when other instruments are also added..
Old 11-15-2004
Newbie
Thanks for the reply. I know that's true so I didn't spend very much time on it--just a quick mix that I can live with in the meantime.
