syncing cubase to analog devices via SMPTE time code
is there a way I can stripe a tape with smpte and have cubase chase the tape machine?? I would have to use the tape machine as the master. Any ideas?
Yes... the idea is you stripe the tape with SMPTE and have Cubase chase the tape machine, using the tape machine as the master.
bruce valeriani recording articles http://www.bluebearsound.com/images/bb_siglogo.jpg |
right... now how would I do it??
You need a device that 1) can put a SMTPE stripe on one track of the tape (typically the last track)........ and 2) has MTC or other sync connectivity the you connect your DAW to so that it can sync with tape.
JL Cooper makes a variety of such devices....
cubase comes with a SMPTE generator that will allow cubase to act as the master when syncing up smpte devices. However, I want to sync cubase up to analog tape, so therefore the tape machine must be the master (because the tape machine itself has no way to read SMPTE). So, can cubase read smpte as well as generate it?
I don't know if the 21st Century versions handle SMPTE directly (i.e. can listen to the SMPTE FSK signal via an audio input) because my Atari ain't broke yet. So if that's your question, I can't help.
However, if it doesn't do that, Bruce answered your question but here's the process in a nutshell...
...Mike. |
