Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 09-13-1999
Cooperman's Avatar
Cooperman Cooperman is offline
1K Silver Member
Cooperman has a reputation beyond reputeCooperman has a reputation beyond reputeCooperman has a reputation beyond reputeCooperman has a reputation beyond reputeCooperman has a reputation beyond reputeCooperman has a reputation beyond reputeCooperman has a reputation beyond reputeCooperman has a reputation beyond reputeCooperman has a reputation beyond reputeCooperman has a reputation beyond reputeCooperman has a reputation beyond repute
Hi everyone,
Can someone explain to me the need for "specialized" monitors for mixing down? When I mix down I just use normal stereo as the monitor. How do "near-field" monitors differ from ordinary speakers?
Thanks
Paul
Old 09-13-1999
Eddie N's Avatar
Eddie N Eddie N is offline
10 Inch Member
Eddie N is on a distinguished road
if a regular home audio system doesnt reproduce details in the sound that studio monitors can , whats the point ? how many people will listen to your mix on near field monitors ? if it aint broke...why fix it ? im not monitor bashing , i want a nice set too , but i just want to understand..
i also understand that studio monitors reproduce the exact frequency response of your mix , so when mixing with studio monitors , you would want to acheive a totally flat sound right ? then , listen to your mix on a range of other systems and see how it sounds... that is correct simply speaking right ?
thanks...
- eddie -
Old 09-15-1999
Fishmed's Avatar
Fishmed Fishmed is offline
Why 2K?
Fishmed has a reputation beyond reputeFishmed has a reputation beyond reputeFishmed has a reputation beyond reputeFishmed has a reputation beyond reputeFishmed has a reputation beyond reputeFishmed has a reputation beyond reputeFishmed has a reputation beyond reputeFishmed has a reputation beyond reputeFishmed has a reputation beyond reputeFishmed has a reputation beyond reputeFishmed has a reputation beyond repute
To get that flat signal for mixing, studio monitors alone won't work. To acheive a flat sound, you should use a two (or dual) 31 band EQ (with the use of an RTA) to even out the imperfections of your control room.
