Try running youe Bass guitar through a compressor, with the Kick Drum inserted in the Side-Chain. The Kick drum can than duck the bass signal win it is applied.
I do this often. In order to afford better control, keep the original kick drum track (which can be EQ'ed seperately as needed), and send it to the compressor side-chain (of the bass track), with an EQ inserted in between. You can then zero in on the clashing frequencies (Remember most compressors will allow you to listen to the side-chain input), and allow the compressor to work only when the clashing frequencies exist (as opposed to constantly ducking the bass with every kick hit). Hope this helps.
Torment, Violent Aggression,
Systematic State of Oppression.
The Heretics, All Swing From The trees,
Cast To Hell, With Their Disease. DARKENED
