Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 11-08-2004
David Grandview David Grandview is offline
Newbie
David Grandview is on a distinguished road
midi recording
Hi
I compose music on a Yamaha Clavinova which has Midi output.
How can I creats a CD so my fiancee can hear the compositions?
Old 11-08-2004
AlChuck's Avatar
AlChuck AlChuck is offline
Been Here, Posted That
AlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond repute
You have to record the audio output of the Clavinova. The most direct approach is to plug in a cable from the line outputs (I'm guessing, but it probably has a stereo pair) to the stereo input of a computer soundcard. Then, you would use a recording program to capture the digitized audio that the soundcard provides into a audio file, and a CD-writing tool to burn an audio CD from the audio files you record.
This is really the wrong forum, but don't feel bad, it seems that a good 90% of people think upon first hearing of it that MIDI is a way of getting sound from one place to another. Actual it's just a standard protocol to describe some elements of musical performance -- e.g., which notes you hit, when you hit 'em, how hard you hit 'em, etc. -- and store or exchange that information. So no actual sound comes out of the MIDI cable when you send a Note On message for the pitch middle C, just a packet on information identifying the pitch and some other things -- for example, a timestamp that tells when it occured, a channel number that identifies which of the sixteen available MIDI channels is used to transmit the message, and what program number the channel's set to (which is used to identify which sound out of a set of available sounds to use when resonding to the message). It's a modern equivalent of a player piano roll -- when sent to the right device -- like another Clavinova -- the stored MIDI information can reproduce the performance within the resolution and level of detail that MIDI allows. But you can only make an audio CD out of what some MIDI instrument renders by responding to the MIDI messages...
Old 11-10-2004
Zona Mona's Avatar
Zona Mona Zona Mona is offline
Dedicated Member
Zona Mona has a reputation beyond reputeZona Mona has a reputation beyond reputeZona Mona has a reputation beyond reputeZona Mona has a reputation beyond reputeZona Mona has a reputation beyond reputeZona Mona has a reputation beyond reputeZona Mona has a reputation beyond reputeZona Mona has a reputation beyond reputeZona Mona has a reputation beyond reputeZona Mona has a reputation beyond reputeZona Mona has a reputation beyond repute
So wait, can I hook the MIDI out to the keyboard from the computer, then connect the audio out from the keyboard to the computer so then the MIDI plays and is recorded at the same time? (Sorry to intrude on your question, but I felt I could save the forum some clutter)
- paul
"Sometimes I think the surest sign that there is inteligent life in the universe is that none of it has tried to contact us"
- Calvin (Bill Waterson)
Proud member of the Ultra-Cool Brigade, with a desperate need for attention
Old 11-10-2004
AlChuck's Avatar
Certainly. They are completely separate data streams and any PC worth its salt can handle that.
You can also record the performance as MIDI, then fix any bad notes or tempo problems, or overdub extra parts and build it up by layering, or transpose it, etc. , etc... then when you're happy, run the MIDI sequence back to the Clavinova and record its audio output as it responds to the captured and edited MIDI messages...
Old 11-11-2004
Zona Mona's Avatar
Dedicated Member
cool, thanks
- paul
