Old 11-06-2004
KevinDrummer KevinDrummer is offline
Senior Member
KevinDrummer is an unknown quantity at this point
Setting levels
I would think that you would want to have the "hottest" signal at the earliest point - but I'm unsure.
What's the proper way to set levels? Here's a sample signal chain...
vocals --> into run of the mill dynamic mic --> into Behrinhger mixer --> into standard PC sound card --> into Cakewalk
I can adjust the trim on the mic pre on the Behringer, adjust the level (channel or main) on the Behringer, adjust my "line in" level on my PC, or the trim in Cakewalk (not sure what that is really doing). What is the procedure to get the best cleanest signal? Would it change if I running a drum overhead? When I arm a Cakewalk channel, I get a flicker on the meter with no signal (at about -66 to -48 db). I'm looking to clean it up. Help. Thanks!
Old 11-06-2004
Cloneboy Studio Cloneboy Studio is offline
Cloneboy Studio will become famous soon enough
Most gear, even not so great gear like that Behringer, has 'sweet spots' where it sounds best. Try to find those.
A good rule of thumb is 70%.
In general if something is set HIGH and something LOW there is something *WRONG* with your setup. Nothing should be cranked or turned down most of the way.
Efficient gain structure is key to a clear recording with maximum headroom, no overs, and optimized signal-to-noise ratio.
I could get more indepth but dinner is ready.
Old 11-06-2004
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
IMHO, and in many other not-so-H opinions, there are reasons to never record OR MIX with peaks hotter than -6dBfs. At least in 24-bit.
That goes for mastering too, but it'll never happen... Distortion that occurs at the D-A is the culprit. It's a long, long story...
Long story short, without the physics lesson that I'm not qualified to give anyway - Keep your peaks at or below -6dBfs for everything. From tracking until the final mix. Only the final master should go over (actually, it shouldn't either, but the Industry won't stand for that I'm certain).
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 11-07-2004
My personal rule of thumb is -15 to -12 dbfs RMS levels with peaks no more than -6 dbfs.
If you have all or a majority of your signal over -6 dbfs the summing will be compromised when you mix down. You will be forced to push some thing down in level and lose some good SNR. Also, you don't want digital summing 'overs' because adding together tracks is exponential.
I would say that over 24 tracks I'd aim for a -18 to -15 dbfs with peaks around -8 dbfs or lower. The more you have to merge, the bigger the chance you may end up with junk.
Digital mixdowns CAN be extremely clean, just like digital recording, if you are careful about gain staging and know what you are doing.
Old 11-07-2004
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
As far as gain staging your board goes. Set the fader on the channel and the output (if you are using it) at unity. There is normally a scale on the faders, unity is the zero mark. Now set the trim on the channel so that the average signal level is about -12 or so in the daw. The soundcard should be set at unity as well. This will get you the best signal to noise ratio you can get.
The standard soundcard is most likely giving you the noise problem.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 11-07-2004
Actually, Ed, didn't you post a link to a paper somewhere (probably one of Aldrich's) about the "physics lesson" that I didn't want to get into? You know, the whole "curve of the peak reaches far beyond 0dBfs" at the D-A...
It'd probably be interesting reading for some around here... If it wasn't you, well... well, then I'm obviously mistaken.
I'll try to dig around and see if I can find it anyway...
Old 11-07-2004
bigwillz24's Avatar
bigwillz24 bigwillz24 is offline
One Turd at a Time...
bigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond repute
Wow I learned something tonight...
I always set everything up trying to get a zero peak on everything and ending up limiting it on the master to -6.
Thanks guys i had been wondering about that too!
Old 11-08-2004
Senior Member
Thanks, everyone. Good points and suggestions. I also found this helpful article:
http://www.soundonsound.com/sos/oct0.../soundcard.htm
