Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 11-06-2004
the blues daddy the blues daddy is offline
Newbie
the blues daddy is on a distinguished road
Cool drum samples into cubase vst 24
Hello there,
My set up:
Cubase VST 24
Omni I/O Studio
Delta 66 Sound Card
I've got the audio recording going on no problem (gutars, base etc).
However, I have downloaded drum samples in 'Wav' and 'MP3' onto my desktop.
I cannot route these into cubase. I have tried 'Import Audio File' and the 'Audio Pool' but with no luck.
Possibly I'm barking up the wrong tree completley. Any ideas would be greatly appriecieted.
Cheers
However,
Old 11-06-2004
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
You need to add a track, import file, it should pop up on the selected track.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 11-06-2004
Bass Jas's Avatar
Bass Jas Bass Jas is offline
[insert brilliance]
Bass Jas has a reputation beyond reputeBass Jas has a reputation beyond reputeBass Jas has a reputation beyond reputeBass Jas has a reputation beyond reputeBass Jas has a reputation beyond reputeBass Jas has a reputation beyond reputeBass Jas has a reputation beyond reputeBass Jas has a reputation beyond reputeBass Jas has a reputation beyond reputeBass Jas has a reputation beyond reputeBass Jas has a reputation beyond repute
Blues, assuming your drum .wav is the same sample rate as your project, you need to right click and add an audio track like Farview said, make sure it is stereo not mono. You might want to give more info on what exactly you are doing ( step by step ). I know I had enough troubles when I first got started.
J
Old 11-08-2004
Newbie
Cool
Thanks for that I'll look into it when I get in tonight.
However, just to let you know...
I have heard of the 'sample rate' before as we came across it when initially setting up.... but I cant remember where it is.
Could you point me in the right direction?
In addition, how do I find out the 'sample rate' of the wav. drum sample? (If this is not possible I presume I just play trial and error with the sampling rate in Cubase).
As far as 'a step by step' of what I'm doing. I presume you mean specific to downloading the drum sample or possibly my tunes in general - either way I'll give ya a breakdown later on as I'm stuck at work at the minute.
Thanks alot...
Old 11-08-2004
Farview's Avatar
Go to edit->project setup -> you will set the sample rate in there. The manual explains all this quite clearly.
Jay Walsh
Old 11-08-2004
Bass Jas's Avatar
[insert brilliance]
Farview has the path right, but I figured out by accident that cubase will play .wav's with diff sample rates with no problem, (they all play real time, regardless of sample rate) Here's how I know: client came in with a karaoke disc, I ripped it and dropped in the stereo tracks, then set up vocal mic like I always do at 24bit/48k, exported mixdown with no probs even though karaoke files were 16bit/44.1k.
I'm thinkin Blues Dad, when you have a project open in Cubase, right click in the tracks section, add audio track, select stereo, highlight the new track, >file>import>audio file, and you should be golden. By the way, mp3's will work, just don't use them, you don't want to open a second can of worms.
J
And Farview, take it easy on the guy with "The manual expains all this quite clearly" no it does not, unless you have experience, and not to insult Blues Dad, but I don't think he has alot of XP, we need to help each other, one nation, under red LED's.
Old 11-10-2004
Newbie
Bass Jas
Thanks for that Bass Jas
Will check it out tonight... meant to have a go last night night but the beer was calling.
and yes your right mate I don't have alot of 'experience of xp'. All help is much appreciated.
Cheers
Old 11-10-2004
Newbie
Result
Result... I am up and running with the sampling... big thankyou's to everyone
Old 11-10-2004
Bass Jas's Avatar
[insert brilliance]
Wink
Blues- let us know when you have a mix up and ready!
I used to have the same problem with beer, it would be calling and mess up a vocal track, then I got a fridge for the garage (next to studio) and keep it in there, it doesn't call so loud anymore, I'm thinking of putting studio foam inside the fridge to further deaden the beer noise!
-Jason
