Fostex vf160 CD WAV Backup
I am using a vf160 to record live where I need a continuous run of up to 90 minutes. I haven't tried it yet, but if a single track goes beyond the size limit of a 700 Mb CD: 1) Will the Fostex automatically split the WAV file when I do a backup? 2) Do I have to split the file somehow manualy before writing it to disk? 3) I'm hosed? I'll need to dump the file through the optical out to a PC or something...
Another option would be to save in the FDMS-3 format. Uses much less space (fewer disks) but can only be read by a Fostex unit, not a PC. I'm curious if cutting the file into 16 pieces, one for eack track would enable the program to be saved on one disk in the wav format... Probably not, but maybe somebody else knows more. |
Fostex CD Wav Backup
Thanks for the reply, from the manual, it looks like the same answer, but I wasn't sure if the manual referred to multiple tracks (wav file for each channel) that it would split or one track that is too large. I will have a chance to try this out soon and I'll let you know how it goes!
You CAN save individual tracks via the wav method. You can also restore or add a wav file track to an existing program. But you have to know what track you're taking off the wav backup disk and you need to know what track you're placing it on. The VF160 will prompt you as to which track you're loading on and which tracks it's going on to. |
>700 MB wav file?
There's no problem with the FDMS3 (FDIO-1) format for disk-spanning saves, but has anyone actually done this for a WAV file in which a single track is greater than the capacity of one CD? What I don't understand is how the WAV file for one track can be automatically reloaded into the VF160 if it spans more than one disk. How do you automatically splice one WAV file to the END of another WAV file (track) on the VF? If both WAV files (part 1 and part 2) have the same name, won't the second loaded WAV file replace the first. Can it actually be done without loading the WAV file parts into different tracks and then editing/splicing them together?
Paj 8^?
8^) |
How is one track being too long for one disk more of a problem than 16 tracks bigger than one disk? A Reload would still involve adding data on a given track to other data previously loaded. But again, I'm probably not getting your point. |
long WAV save
(1) A 45 min WAV file is about 230 MB. (2) For a 700 MB CD-R, that means a 135 min WAV file should be near (but still just under) the single WAV file limit for WAV saves. We need to hear from someone that has saved a single program over 140+ minutes as WAV files. Quote:
(1) A program that has ten tracks and displays 1500 MB at the beginning of the WAV save . . . (2) . . . Has 150 MB of WAV data per track/file . . . (3) . . .meaning that a 700 MB CD-R can hold four tracks as WAV files (4x150=600) with a 100 MB unsued balance. (4) Disk 1 gets tracks 1-4, Disk 2 gets tracks 5-9, and Disk 3 gets tracks 9-10. None of the WAV files gets split. Again, we need to hear from someone that has saved a single program over 140+ minutes as WAV files. Maybe I'll do some copy/pastes on a 45-minute file I'm about to delete. I'll create a single 140-min track and see if I can save it as a WAV file. Later, Paj 8^)
8^) |
long WAV saves
I created a 180+ min file and tried to save it. The VF errors and aborts the save. See my other post: http://www.homerecording.com/bbs/sho...16#post1253316 Later, Paj 8^)
8^) |
