Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 10-22-2004
Janus P Janus P is offline
Newbie
Janus P is on a distinguished road
Compressin bassdrums
i;m reading an article on the basics of mixin and in a part about drums the author says:
If the bass drum is inconsistent then use a compressor to even the levels out, but try using EXTREME compression with a slow attack time. This can put one hell of a *thwack!* into the bass drum.
but what does he mean by a slow attack time? because i would think he means a lot of attack but than it would take longer for the bassdrum to kick in, and that wouldnt make it thwack :S
i'm using the vegas track compressor for all my drum sounds and it looks like the picture below. do you guys think this is good for drum compressing and what values do you think suit the average bassdrum ?
Old 10-22-2004
Newbie
btw i am asking this because a lot of people tell me my drums dont pump enough. i usually put the attack time on 0. but actually i dont really know what all the parameters mean.
Old 10-22-2004
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
Your zero attack time falls into flat out peak limiting, which is good for topping off drum and snare peaks for example.
Try starting there, with a setting that give good amount of limiting happening, then increase the attack time- 5 ms, 10, 20. As you move out in time, more of the attack of the drum is allowed through. You may have to lower the threshold more too to keep compressing. At very short settings, everything triggers in a big way, and is in some ways can be more potent than the ratio setting.
The 'slow' setting they're referring to lets the spike through, then pulls down the body of the signal.
Hope that helps.
Wayne
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
(formerly S.P. Technology
Old 10-22-2004
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
The attack time is different than the attack of the drum.
Attack time is the time it takes (in ms) for the compressor to kick in after the threshold is hit. The longer the attack time the more attack from the original signal gets through.
The release time is how long it takes the compressor to turn the volume back up after the signal drops below the threshold. The faster the release, the more 'boom' you will get from a kick.
play with a slower attack (15 ms or so) and quick release (as quick as it goes) and you will hear the difference.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 10-22-2004
Tim Brown's Avatar
Tim Brown Tim Brown is offline
Why 2K?
Tim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond repute
And don't unless you have built a kickdrum tunnel - don't compress the kick drum when recording- because any stray sounds (snare, cymbals, etc.) that are being picked up by the kick mic will be made louder on your kick drum track!
My band was doing some demo's, and I had a great recording...except for one little thing... somebody (my brother) had re-patched the compressor on my kick channel from post to pre, so I recorded an entire CD worth of material, and the stupid cymbals were as loud as the kick drum on the kick track thanks to compression!
Tim
Old 10-22-2004
Newbie
wwwwwwooooooooowwwwwwwwww thaaannnxx i just found out that the past 2 years i've been messin up my drums because i always put the attack on 0. i just tried what you said and its a maaajoorrr difference!! thanks!!
Old 10-23-2004
KevinDrummer KevinDrummer is offline
Senior Member
KevinDrummer is an unknown quantity at this point
Tim
Bringing up the lower level signals is a function of the "gain" setting. raising the gain brings up ALL the signal, and if you've got any gain higher than 0, it will compress the peaks (above the threshold) and bring up everything (above and below the threshold). It can be useful both ways. I use the gain to bring up my HH sound in relation to the snare since I don't have the HH seperately miked.
Old 10-23-2004
Cloneboy Studio Cloneboy Studio is offline
Cloneboy Studio will become famous soon enough
Jesus, what did he have, a 50:1 ratio at -96db or something?
::in awe::
