Go Back   Home Recording > User Forums by Brand > MiniDisk Forum
     Audiofanzine Homestudio Homestudio News Homestudio Medias Homestudio Tests Homestudio Articles Homestudio User Reviews Homestudio Classifieds Ads
Old 06-08-2000
Nilbog's Avatar
Nilbog Nilbog is offline
hello
Nilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond repute
Wink
Can you only use the inserts for effects on 1 and 2, or can you apply them to any of the tracks? If so, how?
-Nilbog
Old 06-09-2000
gordone's Avatar
gordone gordone is offline
1K Silver Member
gordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond repute
Thumbs down
Nilbog,
You can only use the inserts on channels 1 and 2.
The inserts work differently then the other effects loops. The insert takes the raw channel (track for mixdown and the XLR in for tracking) and puts it through an effects and then returns it right before the pre and the eq. Inserts are used for compressors and eqs where you want the entire signal to be affected whereas a typical fx loop is used for reverbs where the "Wet" signal is sent through a new stereo channel and the "Dry" signal is still intact. The two are then "mixed" together.
Hope that helps! I just got a pair of RNCs and I wish all 4 channels had inserts on them
(I have a MD4S) Oh well!
-Evan
Old 06-09-2000
gordone's Avatar
1K Silver Member
Cool
Oops, I meant to say that when you use the XLR (or 1/4 " balanced) in on channels 1 and 2, the insert's return is after the pre w/ the send after the pre. The effects in in your comp needs a line level signal. Another use for the inserts is to completely bypass the pres and eq for tracking if you use an external pre (which I recommend anyway). Just take the TS cable from the pre-amp out and only push it in util you hear the first "click" Now the out from your pre bypasses the recorder's pres for a more pure sound...
Old 06-09-2000
Ray J Ray J is offline
Force of Nature
Ray J has a reputation beyond reputeRay J has a reputation beyond reputeRay J has a reputation beyond reputeRay J has a reputation beyond reputeRay J has a reputation beyond reputeRay J has a reputation beyond reputeRay J has a reputation beyond reputeRay J has a reputation beyond reputeRay J has a reputation beyond reputeRay J has a reputation beyond reputeRay J has a reputation beyond repute
Wink
ahh. Thanks, very good info to know.
Old 07-06-2000
The Green Hornet The Green Hornet is offline
Been Here, Posted That
The Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond repute
Cool
Yo Nilbog:
Guess who is back to normal???
THE GREEN HORNET
Many Kudos to Dragon for his patience and his expert directions on how to regain my alter-ego.
Happy Summer,
The Green Hornet
Old 07-07-2000
Nilbog's Avatar
hello
Wink
Now you have more posts then me!!
-n
