Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 10-20-2004
Zeekle Zeekle is offline
Junior Member
Zeekle is on a distinguished road
Unhappy Distorted Recording
I have Cubase conected to a Tascam 788 recorder. What I want to do is record a track off the recorder into Cubase. On playback I get an excellent undistorted signal, but when I push record, the signal becomes distorted. Any ideas on why this would happen?? Any help appreciated.
Cheers
Zeek
Old 10-21-2004
crankz1's Avatar
crankz1 crankz1 is offline
crankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond repute
This would have to do with your gain staging. You are most likely recording to hot of a signal and causing digital clipping.
If you are using a standard soundcard or pro, for that matter, don't use a Mic Input unless it is designed to accept line level signals as well.
Pay close attention to the input VU meter to be certain that your level isn't going over 0db. Try and keep the peaks between -6db and -3db. You can safely go a little lower with a 24bit soundcard.
~It all works out in the end~
Old 10-21-2004
Junior Member
Thanks... the gain is OK, reads lower than -6db on the meter. When I'm monitoring I get no distortion, only when I push record. Even then the meter still does not show any clipping has occured or is occuring.
I've used line outs to line ins, also tried S/PDIF out to S/PDIF in with the same result.
This is a method I've used before with a good result but now??
Old 10-21-2004
Halion's Avatar
Halion Halion is offline
1K Silver Member
Halion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond repute
Something could be really wrong with your sample buffer. If you set a buffer size way too small for you computer/soundcard to handle, that can create a whole lot of mess. Try searching where you can set the sample buffer, and set it higher (higher means more latency, but also more chance of undistorted I/O).
Old 10-21-2004
Junior Member
Thanks, will try that. Latency is not a problem as once the track is recorded, I can edit etc on cubase without being sync'd to the Tascam
