Old 10-14-2004
neil3000 neil3000 is offline
Newbie
neil3000 is on a distinguished road
FD4 as a mixer
Hello all.
I have recently purchased a PC that i want to use instead of the fd4 for home recording. But i still want to keep the FD4 and use it strictly as a mixer as I cannot afford another one at the moment (and the built in preamps help as well). The question is, Is this possible??? I know that if there is no storage device (I have an iomega zip100) plugged in, it will not work. Can anyone help me set it up and get it workin. Here is my current gear:
Brand new PC
Delta 44 soundcard
I have a denon reciever i use to power my monitors
and my FD4
also, sometimes the FD4 says "NO DISK" when there is a disk in the drive. and it wont let me do anything!!! Anyone else have this problem???
Thanks Neil3000
Old 10-14-2004
manning1 manning1 is offline
Banned
Location: Canada.PLEASE NOTE>>I DONT WORK FOR NOR HAVE I EVER WORKED FOR ANY COMPANY WHOSE PRODUCTS I LIKE AND RECOMMEND.
manning1 is on a distinguished road
i'm sorry - i dont use the fd4. i use my own designed mic pre's going into my amd computer daw. BUT if your fd4 has a line output from it ,
so as you sing into a mic the signal comes out of a line output of some sort
without recording to the fd4 drive; then you could connect the line output from the fd4 to an input of the 44 and record on the pc.
just an idea.
Old 10-14-2004
A Reel Person's Avatar
A Reel Person A Reel Person is offline
It's Too Funky in Here!!!
A Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond repute
Arrow Yes.
I don't see why the FD-4 could not be used as a front end mixer to a (whatever). The FD-4's mixer section is basically analog, 4x2, and has pretty decent sound. It's not super-high-end in features like some other Tascam analog mixers I could think of, but it should be functional enough.
My qualifications are, I'm a Tascam-based analog enthusiast, but I own and have used the Fostex FD-4. I don't record on PC, and I don't plan to start, any time soon.
Old 10-15-2004
Jim Marquard Jim Marquard is offline
Dedicated Member
Jim Marquard has a reputation beyond reputeJim Marquard has a reputation beyond reputeJim Marquard has a reputation beyond reputeJim Marquard has a reputation beyond reputeJim Marquard has a reputation beyond reputeJim Marquard has a reputation beyond reputeJim Marquard has a reputation beyond reputeJim Marquard has a reputation beyond reputeJim Marquard has a reputation beyond reputeJim Marquard has a reputation beyond reputeJim Marquard has a reputation beyond repute
I have an FD-4, though it sits in the closet since I bought an VF-160 two years ago. As I recall, the mixer section is basically independent of the recording section, other than the fact it won't do anything without a storage device (as you already stated). But otherwise, yes, it will work as a mixer, capable of sending the signal via the RCA outs or the digital out. Personaly, I found that the FD-4 was a pretty decent recorder and it worked very well. I did encounter the "No Drive" problem a few times, but usually it was because I powered up my ORB drive at the same time as the FD-4. If I powered up the drive and let it set up first, THEN start the FD-4 I rarely got the message. I stepped up the VF-160 mainly because I found working with a PC a real hassle--mainly the harddrive not capable of keeping up with the input of musical information. But, then again, my computer is about 6 years old, bought at Walmart, and with a Celeron 533 mHz. If you have a Pentium 3 or better, or the non-Intel equivalent, you should be fine. If you moved to PC recording to increase the number of tracks you can record you will find that you (probably) need a larger mixer, though, your recording program may have a digital mixer that will work well for and then the FD-4 will get you your preamps.
If you are recording all your own instruments and vocals solo you may want to consider investing in a single channel preamp. Most will take mic/line/instrument level inputs and send a line out signal that you can then send to your computer's soundcard. Many on this BBS love the ART MP series. They sound good and cost less than $100, though ART does have some more expensive ones as well. I have one and I like it well enough.
The other thing that you need to be aware of is that not all soundcards are equal. And if yours came with your computer, it is probably not what you really want. On my computer I have a Midiman digital card. It basically accepts a digital signal and sends a digital signal. It does not accept analog so you have to have a mixer with digital outs--and you do with the FD-4. This allows the computer to not have to do any signal converting and should make it work a bit faster. I got my card new for $50, if I remember right. More money, more capability. Still. Something to keep in mind. For $200-300 there are a number of recording sound cards out there that will allow you to bypass an external mixer. Just look on Musicians' friend, American Music Supply, Zzounds, etc. and see what you might want to look for in the future. Remeber, when recording with stand alone units or computers, your recording device is far from the last piece of equipment you will need. So your computer setup, just as with your FD-4, will start making you look to see what else you need.
Well, that was probalby more than what you needed to know, but I hope I helped. Let me know if there is more help that I can give.
Peace, Jim
Old 10-16-2004
Newbie
thanks guys. I figured i would be able to use it as an external mixer. I treid turnung on my drive before the fd4 and it worked fine. Ill keep that in mind. I am still setting everything up as we speak so if i have any problems, ill be sure to post.
Thanks again!!!!!
