Old 10-13-2004
LeeJ LeeJ is offline
Junior Member
LeeJ is on a distinguished road
Question PA question...
I'm looking to bi-amp our live stage setup using 2 x Peavey PV2600, 2 x Peavey Hisys 2xt & 2 x Peavey hisys 115xt subs. Whats the best way to do it?
1. 1 amp powering the top (2xt's) speakers & 1 amp powering the subs
or
2. 1 amp powering the left stack & 1 amp powering the right stack?
Twing - Twang - Twang - !SNAP! - "Bollocks!"
Old 10-13-2004
xstatic xstatic is offline
Been Here, Posted That
xstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond repute
In general, run your biggest amp on subs, your smaller one on tops (not too small of course). It looks like your amps are the same, but i would still run one amp for subs, and one for tops. Newer amps seem to be built pretty well in the power supply and transformer area's, but it is still a good idea to keep the load as even as possible between them which is why I suggest that you use a single amplifier for your subs. This keeps the stress load between the two channels of the amp a little tighter.
Old 10-13-2004
Junior Member
Thank you for you help I'll set it up like you said.
Lee
Old 10-13-2004
Junior Member
Will I need to bridge them somehow??
How will I get the signal from my mixer? Theres obviousley a left and a right XLR outputs on the mixer. but each amp has left and right inputs?????
Old 10-13-2004
boingoman boingoman is offline
moldin' oldie
boingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond repute
You need to get a crossover. Stereo 2-way will do what you want. It splits the signal from your mixer into high and low bands, and provides outputs for each amp.
Splitting the signal keeps lows out of your top boxes and highs out of your subs. It's a much cleaner sound, and more efficient use of power. It lets you select the frequency where the split happens. It also lets you control the level of each band independently, letting you easily adjust your system in different rooms.
Peavey should be able to recomend a crossover point for that system.
Old 10-13-2004
For a half way decent sounding low budget crossover, look into the DBX's, or better yet find an Ashly. Just a rough guess, but start your crossover frequency at about 85 hz if you are using 18's, or 105 hz. if you are using 15's.
